I work with RoboHelp 7.3, and today I encountered a problem that I have not experienced before!
The TOC pane/tab/pod (whichever you call it) has disappeared-- the master(default).
It is not deleted, as I can view it when I generate the WebHelp. Neither can I open it from the Proj Manager- it seems to be hiding behind some other pane.
(do note, I can view the index tab/pane from the Proj Manager—the master(default))
How can I get to view it?
Appreciate your help.
Valee
Hi there
Does clicking File > Load Default Environment help?
Cheers... Rick
Double clicking a TOC in Project Manager should open it.
Hi there
Cheers... Rick
Thank you so much Rick. It is worked out for me
Valee
