1. Re: iOS5 & Falsh Builder 4.5. Problem syncing Debug IPA
Piyush kathayat Nov 3, 2011 6:00 AM (in response to Fil UK)Hi, I am having the same issue while installing my app. did you find any solution for this issue?
2. Re: iOS5 & Falsh Builder 4.5. Problem syncing Debug IPA
Fil UK Nov 3, 2011 6:33 AM (in response to Piyush kathayat)Yep, I managed to get it working in the end, the step that is missing is that you need to manually copy the certificate and provisioning profile over to the the iPhone your testing on. Just hook the phone up to iTunes, let it sync etc as normal, and then just 'drag' the certificate & profile over to the phone, and it should sync them across. If they've synced across succesfully you should be able to see in the settings app that its running your development profile, and then the App should correctly sync.
3. Re: iOS5 & Falsh Builder 4.5. Problem syncing Debug IPA
Piyush kathayat Nov 3, 2011 6:50 AM (in response to Fil UK)Thanks for replay.
Already installed provision file in to IPhone and using same provisioning file for devlopment. Using same build for IPAD and Iphone. It works for IPAD but showing error on IPhone. :-(
4. Re: iOS5 & Falsh Builder 4.5. Problem syncing Debug IPA
Greg Bird Bootech Jan 23, 2012 6:55 PM (in response to Fil UK)Hi,
I am doing this using Windows FB4.5, iTunes 10.5.3.3 and iOS 5.0.1 (iPhone 4s) and have followed the instructions as per http://www.adobe.com/devnet/air/articles/packaging-air-apps-ios.html
Wrt the post saying that it works if you copy the cert and provisioning files onto the iPhone there is no mention of this in the windows instructions. I did try to do this using windows explorer and got an error message however. Does anybody have any more information about this problem as I am unable to even get a Hello World installed on the iPhone.
Greg
5. Re: iOS5 & Falsh Builder 4.5. Problem syncing Debug IPA
Fil UK Jan 24, 2012 2:13 AM (in response to Greg Bird Bootech)Hi Greg,
If you go into the 'General' tab of the 'Settings' app on your test device, do you have an entry one up from the very bottom called 'Profile' and showing the name of the provisioning profile you created? If you can't see the Profile entry there, then you won't be able to Sync the test App.
I ended up giving up on iPhone Dev via FB, although it was a little more friendly than xcode, the basic control set was just far to limited for general purpose development.
Cheers,
Phil
