Show 1 reply
1. Re: Trying to crop layer, getting "Can't complete because smart object not editable" message
MTSTUNER Sep 9, 2011 5:02 PM (in response to (d))You don't won't to crop the whole photo, just delete the area from the layer
that you've selected?
Two ways:
1. Go to Layer>Simplify Layer before using delete.
2. If you want to keep the smart object, select the area you want to keep, not
delete, then hit the Add Layer Mask button at the bottom of the layers panel.
A smart object is usefull for resizing an image layer over and over without losing
quality (the image doesn't pixelate like it does on a non smart object)
If your not planning on doing lots of resizing or transforming on the layer, then removing
the smart object by Layer>Simplify Layer won't make much difference.
MTSTUNER
