How delete a book from Digital Editions?
Engaged ,
Aug 22, 2010 Aug 22, 2010
How can I delete a book from Digital Editions?
Also, is there any way to get an email notification when a reply is posted to my question? Thanks.
Install ADE
20.0K
Aug 24, 2010 Aug 24, 2010
When you highlight a book a small right facing arrow will show just to the left of the book title.  Click on it and a pull down menu appears with several options.  One of them is "delete".
Hope this helps.
Guest
Jun 08, 2011 Jun 08, 2011
How easy was that - perfect!!  Thank you so much - sometimes I wonder about myself and make things too hard!
Guest
Aug 07, 2011 Aug 07, 2011
And how do I delete 1,000 books at the same time?
Engaged ,
If you have that many, I'd suggest using some of the utility software on
your computer. Assuming Windows, this would be Windows Explorer (NOT
Internet Explorer). I'm also going to assume a reasonable level of computer
skill in my comments below.
Go to My Computer and locate the Digital Editions folder. Browse around in
that folder until you find your ebooks (making sure that they're in the
right place). If you want to delete ALL of the ebooks, go to the top bar of
Windows Explorer and click on 'Edit'. Then, go to the bottom of the
drop-down menu and click on 'Select All'. Then, press the Delete key.
If you want to delete only 'some' (1,000 is 'some') but not all, you
can create a temporary folder outside of the Digital Editions folder, then
go back to Windows Explorer and open the Digital Editions folder. Select
the ebooks you want to keep, go up to the command bar and select 'Edit'
again. Then, select either 'Copy to folder' or 'Move to folder', depending
on whether you're selecting the ebooks for deletion or those to keep. A
pop-up screen will let you select the folder that you just created. Then,
press the 'OK' button and Windows will do the rest.
If you followed the process to move the ebooks for deletion to the temporary
folder, you can delete that folder and you're done. If you picked those
that you want to keep, then you can go back to the Digital Editions folder,
do a 'Select All' again and delete the ones that are going bye-bye. Then,
use Windows Explorer to open the temporary file, do a 'Select All' on it,
and a 'Move to folder' to put the ebooks back in the Digital Editions
folder.
When you open ADE, it does a scan of the Digital Editions folder to create
its list for the Library display, so you won't have to worry about changing
that part. Just make sure you haven't deleted any ebooks that you're in the
process of reading - that would cause an error in ADE.
Hope this helps!
Guest
Aw, thank you for your detailed response. However, I AM on a Mac. Might you know how I do it there?
Engaged ,
Sorry, but I don't know the MAC world. The concept is the same.
Mar 02, 2012 Mar 02, 2012
Hi, I downloaded my ebooks to digital and than I accidentally re-downloaded the same ebooks again, so instead of 2500 ebooks in my library, I now have double copies of everything, so I need to delete the other 2500 ebooks, without doing it one by one.  I tried your suggestion and deleted all files and even the program from the control panel, and even emptied to recycle bin so that I thought  everything pertaining to digital editions was completely gone, but when I go and re-download and launch ADE again from scratch, all the ebooks are there again. Is there a file I am missing to delete?  Is there another way to delete mass ebooks?  I have been doing this run-round for two days now and am totally frustrated.
Any help would be greatly appreciated.
folder.
Hope this helps!
Guest
Jan 07, 2012 Jan 07, 2012
This deletes the book from being seen in Adobe Digital Editions, but does not remove the files in MY DOCS/MY DIGITAL EDITIONS. There are files in 4 folders and multiple for each book. Overtime this creates a huge unaccessible file on the computer. For instance, I deleted a book, but if you go to MY DOCS and click on the book.epub file, it still pulls up in Adobe Digital Editions and is readable, but not shown on the bookshelf any longer.
Aug 10, 2016 Aug 10, 2016
This does not seem to be working on my Mac OSX. I highlight the item and no arrow appears anywhere. Thoughts?
Oct 03, 2019 Oct 03, 2019
I just tried this on version 4.5 and it does not work on my MacBook. Can you help? Also I have used my Adobe ID to authorize my laptop pc but now want to authorize my MacBook and Adobe says I can't use the same ID to authorize another device. Can you help?
Guest
Sep 10, 2011 Sep 10, 2011
thank you so much for your help I had tried everything and was beyound frustrated.Who new it could be that easy!
Nov 23, 2015 Nov 23, 2015
‌Amazingly this is still the top hit for this question.  On an iPad, to the right of the title in question, swipe left.  That will bring up options to mark as favorite or delete.  Took me a few minutes to stumble across this and on my own.
Feb 14, 2021 Feb 14, 2021
I did that. However, the book still remains with a greyed out cover and Author Unknown. So, the question is how to remove the book's icon entirely. I used to also have this problem in MacOS, but now the icon seems to be removed completely. At one point, I had 30 or 40 icons (most of them checked out from a digital library). I managed to remove them on my Mac, but not so far on my iPad Pro.
