Running FDS as a true service
Avatar
Level 1
I have FDS installed on Windows Server 2003. It runs fine as
long as I'm logged in, but the server seems to shut down when I log
off. I don't want to leave the server logged into an account all
the time. This introduces a lot of security concerns. Is there a
way to set it up as a true service so that it will continue to run
without an account logged in?
Avatar
Former Community Member
Hello:
It really depends on the J2EE server you are using. FDS runs
under a web
application on that particular server, so let us know what
you are using.
Jorge Hernandez
Flex QA Engineer
"VoodooPuppy" <webforumsuser@macromedia.com> wrote in
message
news:ecqb2u$ahv$1@forums.macromedia.com...
as long as I'm
>logged
> in, but the server seems to shut down when I log off. I
don't want to
> leave the
> server logged into an account all the time. This
introduces a lot of
> security
> concerns. Is there a way to set it up as a true service
so that it will
> continue to run without an account logged in?
Avatar
Level 1
For example, with the embedded JRun j2ee server that installs
with Flex (which is a convenience, not a requirement), use the
jrunsvc command to install as a windows service: see
http://livedocs.macromedia.com/jrun/4/Installing_JRun/install5.htm.
Once you have done that, set the following property in the
{app_name}\WEB-INF\flex\flex-config.xml for the specific Flex
app(s) that will be running on a headless server (which could be
your case):
When headless-server is true, the system property
java.awt.headless will be set to true.
This should be used with JDK 1.4+ on servers without
graphics cards and
monitors. Otherwise, the property is not set.
<headless-server>true</headless-server>
