Hello I have this query in my cf program
First query
SELECT TLA_PROP.PIN, TLA_PROP.ASSR_PRCL_NBR, TCASE.CASE_NBR,
TLA_PROP.STR_NBR, TLA_PROP.STR_NBR_RNG_END, TLA_PROP.STR_FRAC_NBR,
TLA_PROP.STR_FRAC_NBR_RNG_END, TLA_PROP.STR_DIR_CD,
TLA_PROP.STR_NM, TLA_PROP.STR_SFX_CD, TLA_PROP.STR_SFX_DIR_CD,
TLA_PROP.STR_UNIT_TYP_CD, TLA_PROP.UNIT_NBR,
TLA_PROP.UNIT_NBR_RNG_END, TLA_PROP.ZIP_CD, TLA_PROP.ZIP_CD_SFX,
TLA_PROP.CNCL_DIST_NBR,
TLA_PROP.PLAN_AREA_NBR, TLA_PROP.ZONE_REG_CD,
TAPLC.PROJ_DESC_TXT, TCASE.CASE_ID, TCASE.CASE_NBR, taplc.aplc_id
FROM TLA_PROP INNER JOIN ((TAPLC INNER JOIN TCASE ON
TAPLC.APLC_ID = TCASE.APLC_ID) INNER JOIN TLOC ON TAPLC.APLC_ID =
TLOC.APLC_ID) ON TLA_PROP.PROP_ID = TLOC.LOC_ID
WHERE TCASE.CASE_NBR Like '%HPOZ%' and TCASE.CASE_NBR =
'#form.caseNbr#'
'#form.caseNbr#' is the input field on my input box.
I am a beginner and I am not used to joins and joins in the
from class
Second query
In toad I use this query
Select
tcase.case_id
,Tcase.case_NBR
,tcntct.CNTCT_ID as ownerInformation
,tcntct.CO_BUSN_NM, tcntct.FRST_NM, tcntct. LST_NM
,tcntct_owner.cntct_id as repInformation
,tcntct_owner.CO_BUSN_NM
, tcntct_owner. FRST_NM
, tcntct_owner.LST_NM
,Tref_plan_area.plan_area_desc
,tcase_req.case_req_id
,tcase_req.case_req_typ_cd
,tcase_req.sys_user_id
,tla_prop.pin
,tla_prop.cncl_dist_nbr
,tla_prop.PLAN_AREA_NBR
,tla_prop.str_nbr
,tla_prop.STR_FRAC_NBR
,tla_prop.STR_DIR_CD
,tla_prop.str_nm
,tla_prop.STR_SFX_CD
,tla_prop.STR_SFX_DIR_CD
,tla_prop.STR_UNIT_TYP_CD
,tla_prop.UNIT_NBR
,tla_prop.ZIP_CD
,tla_prop.ASSR_PRCL_NBR
,TLA_PROP.ZONE_REG_CD
from
tloc, tla_prop , tcase, tref_plan_area,
tcase_req,tcntct_aplc, tcntct, tcntct_aplc tcntct_aplc_owner,
tcntct tcntct_owner /*tcntct_tla_prop,tcntct*/
where
tla_prop.prop_id = tloc.loc_id
and
tla_prop.plan_area_nbr = tref_plan_area .plan_area_NBR
and
tloc.aplc_id = tcase.aplc_id
and
tcase.case_id = tcase_req .case_id
and
tcase_req.CASE_req_typ_CD like '%HPOZ%'
and
tla_prop.prop_id = tcntct_tla_prop.PROP_ID(+)
and
tcntct_tla_prop.CNTCT_ID = tcntct.CNTCT_ID(+)
and
tcase.aplc_id = tcntct_aplc.APLC_ID(+)
and
tcntct_aplc.cntct_id = tcntct.cntct_id(+)
and
(tcntct_aplc.CNTCT_TYP_CD = 'A' or tcntct_aplc .cntct_typ_cd
is null)
and
tcase.aplc_id = tcntct_aplc_owner .aplc_id(+)
and
tcntct_aplc_owner.cntct_id = tcntct_owner.cntct_id (+)
and
(tcntct_aplc_owner.cntct_typ_cd = 'R' or
tcntct_aplc_owner.cntct_typ_cd is null)
group by
tcase.case_id,
Tcase.case_NBR,
,tla_prop.pin
,tla_prop.str_nbr
,tla_prop.str_nm
,tla_prop.UNIT_NBR
,tla_prop.ZIP_CD
,tla_prop.ASSR_PRCL_NBR,
tcntct.CO_BUSN_NM
, tcntct.FRST_NM
, tcntct.LST_NM,
, tcntct_owner.FRST_NM
order by
to get
Tref_plan_area.plan_area_desc or simply get plan_area_desc.
This is done through a join tla_prop.plan_area_nbr = tref_plan_area
.plan_area_NBR .
I am still using the first query ( the very first query
above) but there are joins in the from clause.
My question here is I am still trying to get plan_area_desc
and want to incorporate some syntax from the second query to the
first query.
What I did that was a mistake was ( error)
Added the table from and put this tla_prop.plan_area_nbr =
tref_plan_area .plan_area_NBR .
In the where clause. It did not work. Can any one help me on
how I can still get the tref_plan_area .plan_area_NBR .
What do I add to the first query
