I have created a form and look ok but when I enable Reader Extended PDF -> Additional Features form giving following error. How can I fix that?
Regards
Solved! Go to Solution.
Total Likes
1. set the debitamount fields to float
2. Change the script the get the amount from
into
Total Likes
The message indicates that you use a dot notation for the integer value of the field "debitamount", which is fundamentally wrong, as integers never have decimal places.
If you use decimal numbers in that field you have to change it's data format to "float".
Total Likes
When I select Float, debitamount fields under Method 1 and 2 no longer getting the total amount from the table in the first page!
Total Likes
Any help much appreciated.
Total Likes
into
Total Likes
Thanks very much, much appreciated.
Regards
Total Likes
