Hi
We have a situation , we have a web application which further has multiple flex applications.
We have 2 Servers say Server 1 and Server 2.
Build process runs on Server 1 using ANT and then the Output is Deployed on Server 2 using Powershell.
We are using Flex 3.5 SDKs to compile our flex applications.
We have License for FB3 Pro , FB4 Premium and FB 4.5 Standars.
We dont wish to Install FB but just Install Licenses.
Question is where should we install the License , Which Server ? and what is the way to do it.
I read we can add arguments in build files under compile section but how the exact argument should be.
Mohit
Hi Mohit,
Licensing should be applied on the machine in which the Flex application is being compiled. During compilation itself, Flex compiler looks for licensing info to remove restrictions.
http://raniskumar.wordpress.com/2009/07/28/flex-builder-license-and-automation-flex-3/ explains different ways to apply license in Flex 3. Same steps apply for FB 4 as well but the name "flexbuilder3" should be changed to "flashbuilder4" in case of FB4.
Hope this helps.
Deeptika
