Hi All
I've done some quite major updates to a help project,
including the creation of new context sensitive help Map Ids.
When I generate the help I get two files, cshdat_webhelp.htm
and cshdat_robohelp.htm. The cshdat_webhelp.htm contains the
correct map ids, however cshdat_robohelp.htm is still picking up
old IDs and some that look like random IDs, and this appears to be
the file that is called from the top level file
(projectname_rhc.htm) that the application calls. We can't get the
app to work with the projectname_csh.htm, so we need to use the
projectname_rhc.htm and cshdat_robohelp.htm files.
The only map file used in the project is the BSSCDefault.h
file, which only contains the correct IDs. I can't understand where
it is picking up the old/incorrect map IDs from. Can anyone please
help??
Thanks in advance,
Emma.
