I edited the styles of my project so that the H2 and H3 tags
have a particular look (H2 is an indented blue, bolded, highlighted
text and H3 is an indented, bolded, underlined text). It looks fine
in RoboHelp's WYSIWYG, however when I generate the output (I've
generated it to Word, PDF, WebHelp, and HTMLHelp) not only are the
header tags being formatted, but all of the "Normal" text below it
is being formatted the same way, up until it reaches another
header. So an H2 header will format the header as well as the
paragraphs below it until it reaches an H3, at which point it will
format all of the text according to that style.
Some background, this was originally a PDF that I imported
and then had to manually re-format because it imported so
strangely. I deleted all of the styles that it created when it
imported and then created styles for "Section" and "SubSection".
Later I used a find and replace program to change all of the p
class=Section tags to equal H2 and the p class=SubSection to equal
H3. The output is acting almost as if the tags are not closing.
Which is interesting, because I couldn't close them through the FAR
program, but when I opened the topics up in True Code view,
RoboHelp had changed all of the /p to /h2 or /h3 automatically.
Thoughts/Suggestions?
