1. Re: Chapter/Page numbers in TOC are wonky
Arnis Gubins Sep 16, 2011 9:57 AM (in response to farrelldoc)Karen,
How are the the autonumber components defined in the source paratags for the <$paranum> ? Usually, one should be using the <$chapnum> building block instead of trying to pull the <$paranum> for a chapter-page style of TOC entry.
2. Re: Chapter/Page numbers in TOC are wonky
Error7103 Sep 16, 2011 9:58 AM (in response to farrelldoc)What Reference Page is that?
Typically, Reference Page "TOC" has text structure like:
openObjectId <$relfilename>:<$ObjectType> <$ObjectId>
<$paratext>{tab>}<$pagenum>
<$paratext>{tab>}<$pagenum>The generated TOC entries take their formatting from the paragraph formats assigned to the RP lines, like Heading1TOC. Select each line below OpenObjectId and make sure it has the formats you want.
If the source text in the BODY file has a Character Format applied, and that ChFmt is defined in the TOC file, the TOC's ChFmt format is also appled in the generated text.
