I am trying to use the following in my server side script......I've been using these for years but they don't seem to work in FMS 4.5 do I have to upgrade my scripts to continue using them or are these still available? I can't google anything on them so please shed some light on this. I'm going to continue digging into FMS 4.5 in attempt to fix this without a SSAS rewrite. For anybody who is intrested I will be reporting back to this thread when i resolve this issue.
load("framework.asc");
load("netservices.asc");
gFrameworkFC
Brian, you're the only person that can tag this post as answered. Points aren't that important, making sure others are pointed in the right direction is though
Thanks for trying FMS 4.5.
No changes have gone in to this part of the server. The scripts should work just fine. Can you please let me know what's the issue here ? Are the scripts not loading at all or are there any errors blocking the load ?
Thank you for your cooperation.
These are the errors i get are the paths and file names to the framework and netservices correct? This server side script works fine in FMS 3.5 and 3.0. What is the path and names of the files for framework.asc and netservices.asc or equvilent on FMS 4.5? I usually can find these within the FMS installation directories but I can't find them anymore.
gFrameworkFC
Sending error message: C:\Program Files\Adobe\Flash Media Server 4.5\applications\test\main.asc: line 251: ReferenceError: gFrameworkFC is not defined
Sending error message: C:\Program Files\Adobe\Flash Media Server 4.5\applications\test\main.asc: line 103: ReferenceError: gFrameworkFC is not defined
I am not sure why these files are missing, they should not be. I will track that problem. Meanwhile, can we try few quick things please ?
1. Did you check the scriptlib directory under FMS installation to see if the script files are already present ?
2. Copy the script files from FMS 3.5 installation (if you still have it somewhere running) and keep them in the same place on 4.5 as they were on 3.5. Did you try this already ?
Thank you !
I have the following files in C:\Program Files\Adobe\Flash Media Server 4.5\scriptlib
(folder) webservices>>>>>>my target file framework.asc is not in any of these folders but as you can see below netservices is there.
NetServices.as
netservices.asc
RecordSet.as
RsDataProviderClass.as
Could you give me a link to fms 3.5 or 4.0 so I can install it in VM and extract the file?. I upgraded the old and as you know most of the files were deleted(next time i test new FMS within VM)
Here is the code of framework.asc. Save it in scriptlib and see if it helps. Thank you !
try { var dummy = gFrameworkFC; } catch ( e ) { // #ifndef gFrameworkFC
// Create the global framework object singleton. This will
// serve as a place to hold various global framework objects
gFrameworkFC = new Object(); //
// A utility routine to convert an object into an array
// USE WITH CARE! In general it is only meant to be used
// for converting arguments into a real array so concat()
// works properly.
gFrameworkFC.__toarray__ = function(obj) {
if ( typeof(obj) != "object" || obj.constructor == Array || obj["length"] == null )
return obj;
var a = new Array(obj.length)
for ( var i = 0; i < obj.length; i++ )
a = obj;
return a;
// Load all core framework files
load( "application.asc" ); // Load the ApplicationWrapper
load( "facade.asc" ); // Load the component facade
// The next available client id.
gFrameworkFC.nextClientID = 0;
// Setup a 'per client global storage' area so that different components
// can share per client data without having to attach it to the client
// object.
gFrameworkFC.clientGlobals = new Object();
// Accessor for client globals
gFrameworkFC.getClientGlobals = function(client) {
return this.clientGlobals[client.__ID__];
// A component is available only if its constructor function
// is registered here. For e.g. consider a chat component called
// FCChat, then gFrameworkFC.components["FCChat"] == FCChat.
gFrameworkFC.components = new Object();
// Register a component
gFrameworkFC.registerComponent = function(name, componentClass) {
gFrameworkFC.components[name] = componentClass;
// Setup ourselves as a listener on the actual app object
gFrameworkFC.application.addListener( componentClass );
componentClass.onAppStop = function() {
var result = true;
if ( this.instances != null )
for (var i in this.instances)
if ( this.instances["onAppStop"] != null ) {
var result1 = this.instances.onAppStop();
if ( result1 != null )
result = result && result1;
return result;
componentClass.onDisconnect = function(client) {
for ( var i in this.instances )
if ( this.instances["onDisconnect"] != null )
this.instances.onDisconnect(client);
trace( "Communication Framework loaded successfully." );
} // #endif
i think now u will be requiring the other files as well (facade.asc and etc).
FMS 3.5 should be in the download section on adobe.com. Else i need to zip the scriptlib directory and send that to you. Mail me @ npkalyan@adobe.com
These are my current errors I'm going to go attempt to download 3.5 and get the scriptlib. While I do that do you identify something else I need to do from the below error?
Sending error message: C:\Program Files\Adobe\Flash Media Server 4.5\applications\test\main.asc: line 103: TypeError: gFrameworkFC.getClientGlobals(client) has no properties
Sending error message: C:\Program Files\Adobe\Flash Media Server 4.5\applications\test\main.asc: line 251: TypeError: gFrameworkFC.getClientGlobals(oldClient) has no properties
checking client status... 80
Thanks for taking the pain to download 3.5 for the scriptlib.
The errors are all due to the missing files from scriptlib. AFAIK, these files are not to be deprecated, I would find out if they are removed or really 'missing'.
I will redownload and install FMS 4.5 in VM. I doubt it but maybe my machine is comprimised and somebody deleted files to mess with me. Time will tell.
No, that's not the case, I have already checked a local copy of 4.5 on my machine and the script files are not present. So your 4.5 installation was correct (sorry i missed to confirm this previously).
As i said, AFAIK, these files are not to be deprecated, I would find out if they are removed or really 'missing'.
Ummm are you an adobe employee? How am i supposed to find out if adobe actually removed them? I've been searching this problem all weekend on google and adobe.com and there is exactly zero information on it. What should I do ? PS zip and send scriptlib I cannot download FMS 3.5
I would help in finding out why they are not added on 4.5. I am unable to attach zip files in the forum. You might have to provide me other alternatives. my mail is npkalyan@adobe.com
i emailed you already with my primary email however here is my secondary. Sometimes my other email has problems getting into highly secure mail servers as it is a private domain and might appear as spam calm_chess_player@yahoo.com
Now it works! Thanks for you support. Please find a defenitive answer to this issue or tell me how to contact somebody whom can answer this question. If those files have been purposly removed then I need to start researching how to rewrite my scripts. I have 6 customers that use some form of the main.asc that I'm having problems with. I need to warn them or offer to upgrade them. I smell work!
I have responsed on your private mail.
For the information to the rest of the poeple here, it seems the files have been depreacated on 4.5.
Thank you for your time. I will warn my customers that they cannot upgrade to FMS 4.5. I await an update to the information you provided in my private message so i can begin to rewrite these scripts. Unfortunately I cannot give you points. I'm trying to catch you on the ladder
Adobe stopped adding these files in from 4.0 if I remember correctly. You have to copy them over from previous installations. These scripts are so ancient, and they will never be updated from my understanding. Depreciated or not.
My suggestion would be to move on from them and create your own framework. Although there is the age old saying of "if it aint broke then don't fix it".
You can upgrade but you have to manually copy over the files. It should work just fine.
Thanks Graeme I'll inform my customers of my ignorance when I created that main.asc and tell them how to upgrade. The script does continue to work after coping the correct files that it needs from FMS 3.5.
Hi all,
@ Greame , There are few scripts that are removed on 4.0 (the components section especially) , and some more are removed this time in 4.5
I have not checked the doc actively, but please let us know if this has not been documented properly.
Thank you all.
For most it comes as a very large surprise. I have no idea if that point is in the docs, I've never seen it, can you find it easily in there? Luckily Adobe keeps the past versions on their site and it's just a matter of going to go get them (a pain, but that's the cost of maintaining ancient code I guess).
Dear Adobe I'm trying to tell my customers how to modify FMS 4.5 so they can use the scripts as I've posted above this post however I and they are concearned that if we take FMS 3.5 files and put them on FMS 4.5 that we will break their TOS/Liscense Agreement. What are the legal issues we need to be concearned with?
