1 5 6 7 8 9 Previous Next 323 Replies Latest reply on Aug 20, 2012 1:03 PM by Peter Spier Go to original post
      • 280. Re: Problems making a PDF from Indesign CS5
        claidheamdanns Level 1
        For me, I tried disabling them, and in fact, even completely uninstalling them, and it didn't help at all.
        • 281. Re: Problems making a PDF from Indesign CS5
          goanna2 Level 1
          Hi Matthew
          Is this particular problem related to how InDesign5 now handles fonts or just with the Extensis plugin? I have never had Extensis on this computer and only use Font Book to manage my fonts. To cope with these continuing InDesign problems I have increased my ram to 16gb (no noticeable improvement), but have suspected fonts might be the problem for some time.
          • 282. Re: Problems making a PDF from Indesign CS5
            Matthew Laun Adobe Employee
            All,
            Again, I'm talking only in the context of PDF export failures that go away when you use the script to force the export to the foreground.
            There are multiple root causes involved, all of which have to do with some piece of code not anticipating the fact that the PDF export is on a background thread. We've got one fix in 7.0.3, there are changing in an upcoming update that will hopefully resolve some of the instances associated with Extensis plug-ins and other scenarios, and we are workign with Extensis to guide them on updates that they can make to avoid issues.
            If you have a failure that does not go away with foreground exporting, then it shouldn't be discussed on this thread.
            Matthew
            • 283. Re: Problems making a PDF from Indesign CS5
              JanGer
              Matthew,
              For your information:
              -     I have this problem on the Windows platform (XP Pro with Service Pack 3)
              -     ID version running = 7.03
              -     No Extensis plug-ins installed
              -     And the problem does go away when I force the export to the foreground (using the "book" option, just tested this to confirm)
              When exporting in the background, I'm able to export one (1) PDF, the subsequent exports stall and I have to force quit Indesign and restart to get it working (i.e. I'm then able to export just one PDF again...)
              Luckily ther is the book workaround :-)
              Jan
              • 284. Re: Problems making a PDF from Indesign CS5
                Lucien Schilling Level 1
                function(){return A.apply(null,[this].concat($A(arguments)))}
                BobLevine wrote:
                This is not a direct line to Adobe. It's a user to user forum.
                If you wish to make you case directly, do so here: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
                The more people they hear from the better.
                That said, I've yet to see this issue and while there have been several reports, it doesn't seem like a widespread problem, so the more details you can provide the better chance of seeing it fixed.
                Bob
                Adobe monitors the forum...
                • 285. Re: Problems making a PDF from Indesign CS5
                  Peter Spier Most Valuable Participant (Moderator)
                  Some employees monitor some threads some of the time. Most of time they don't participate, and this is not a channel to tech support. Matthew Laun has taken an interest in this particular problem, but this is a rare exception.
                  • 286. Re: Problems making a PDF from Indesign CS5
                    And Bob made that comment almost a year ago when this thread was just starting,and it was quite pertinent then.
                    • 287. Re: Problems making a PDF from Indesign CS5
                      Thomas Dearie Level 1
                      I trust you're right, Peter, though I certainly don't know one way or the other.
                      Users come here hoping to converse with Adobe on various issues because they're desperate and don't know of any other outlet to do so. It's a symptom that some kind of venue for robust dialogue between the user community and Adobe is much needed.
                      Submitting a bug report through the submission system is prudent advice, but it's one way communication and isn't a substitute for open dialogue. It feels like shouting a wish down a well, and doesn't solve the user's immediate need for information.
                      With individual technical support being overwhelmingly expensive for both users and the developer, there's a need for more proactive and innovative ways for users and Adobe to communicate (and elucidate and tackle sticky technical problems).
                      Matthew's involvement here has given users productive feedback that is complementary to that provided by other users and is a step in the right direction.
                      I'm not suggesting that this forum is or isn't the ideal venue for this (I think there are other ways to address these issues and provide after-market value to users).
                      But, as long as users have nowhere else to go, I think we'll keep seeing people resort to the forum as a communications outlet.
                      Cheers
                      Tom
                      • 288. Re: Problems making a PDF from Indesign CS5
                        @JanG,
                        I've very much like to get your document to try to reproduce. The more reprodocible cases, the better our odds at tracking down all defects related to code not adjusted to handle the case of background threaded export. If you can, package the file, add your preflight profile (if not using the default) and PDF settings file (if not using one of the canned versions, in which case, let me know which), then post to share.acrobat.com, yousendit.com, etc, and send me the link. Oh, you can send a private message by clicking on my name anywhere in this thread and look to the upper right for the "Send Private Message" command.
                        Sincerely,
                        Matthew
                        • 289. Re: Problems making a PDF from Indesign CS5
                          Thomas, very well put. I could not agree with you more.
                          And I would also like to say a big THANK YOU to Matthew for his involvement on this forum.
                          • 290. Re: Problems making a PDF from Indesign CS5
                            John Hawkinson Level 5
                            What Peter is saying, and it is important to say, is that users coming to this forum should not make the mistake of presuming that Adobe personnel are reading the threads and seeing what they say. This isn't to discourage people from coming here and posting. But sometimes people get the impression that Adobe is reading what they say here (or that Peter is an Adobe employee); those things aren't true and it's worth making sure people do not labor under a misapprehension.
                            • 291. Re: Problems making a PDF from Indesign CS5
                              Absolutely.
                              It's a helpful thing for users to know, and I'm sure that was the intent.
                              It just illuminates a relevant issue that's worthy of note.
                              As you say, we wouldn't want to discourage people from using the forum to try to open dialogue with Adobe. Quite the opposite - they should jump in and hope for the best since, for now, the forum is the only game in town.
                              Although it's imperfect for this purpose for the reasons you noted, in this case, the dialogue has been useful and welcome. I'd like to see more of it.
                              With luck, these discussions stimulate new ideas that can benefit users and developers alike.
                              • 292. Re: Problems making a PDF from Indesign CS5
                                Thomas: On a positive note, Brian Nemhauser, Adobe's new Director of Product Management for InDesign and Illustrator has started taking a more public role. He de-lurked over on InDesign Secrets  last week: http://indesignsecrets.com/indesign-cs-5-5-announced.php#comment-490404.
                                He also recently started using Twitter: @briannemhauser, so I think he is interested in engaging with customers, at least to some degree.
                                I'd encourage you to encourage him to be more active on these forums, and to have his technical staff do so as well. (I've already done so, but I imagine it's more useful to hear it from other customers, too.)
                                • 293. Re: Problems making a PDF from Indesign CS5
                                  Yes - I noted that with interest (as I flew through my office on roller skates from one task to another).
                                  His commentary sounded encouraging.
                                  Cheers
                                  Tom
                                  • 294. Re: Problems making a PDF from Indesign CS5
                                    AnneMarie Concepcion Adobe Community Professional
                                    "he de-lurked over on InDesignSecrets.com" ... lol.  Like de-cloaked, as in Romulan?
                                    AM
                                    • 295. Re: Problems making a PDF from Indesign CS5
                                      Yup, that's right! It's actually quite a common term around here so I use it without thinking (that might tell you something about the environment I live in...).
                                      I certainly didn't mean to imply that InDesign Secrets was some kind of Neutral Zone and that we would have to be concerned about the Phasers and Photon Torpedos. Definitely nothing like that.
                                      Especially because Cmd-Opt-Shift-K doesn't do anything useful in InDesign. At least, not like it does in a certain other product. (I'm sure there are people who really use Clipping Path: Options... and would be heartbroken if it caused an interstellar incident).
                                      • 296. Re: Problems making a PDF from Indesign CS5
                                        Fludium
                                        I have been experiencing the same problems with files created in CS5, so it can't be a legacy issue for me. I have battled with making HR pdf's for printers for months now, and I've tested all the elements eg text to outlines, deleting guides etc and the only thing that works every time is pasting the artwork into a new document. It must be a bug to do with document setup??
                                        Try that next time!
                                        • 297. Re: Problems making a PDF from Indesign CS5
                                          JanGer Level 1
                                          Thanks Matthew.
                                          I sent you a private message with the link to the document.
                                          Jan
                                          • 298. Re: Problems making a PDF from Indesign CS5
                                            The community is great and helps for 99% of the problems. The other are those problems Adobe is interested in.
                                            • 299. Re: Problems making a PDF from Indesign CS5
                                              But you cannot presume that a post here will be seen by the right people (a real bug report will get directed to the correct people on the team), nor that you will get any feedback if it does.
                                              • 300. Re: Problems making a PDF from Indesign CS5
                                                Correct. But Adobe does not respond always to real world problems that have been notified to Adobe using the "official" way! At least here you get help, if possible or you get directed to the corresponding pages, if you need to report an other way.
                                                • 301. Re: Problems making a PDF from Indesign CS5
                                                  Hmm. Well, tonight I happened to discover independently that InDesign does already cause interstellar incidents:
                                                  I see that InDesign Secrets posted about this some years ago. All I can say is that nobody told me how to do it, I managed to figure it out myself. That said, you would like to think there'd be some CS5.5 ones floating around somewhere...
                                                  • 302. Re: Problems making a PDF from Indesign CS5
                                                    PagePenna
                                                    I have also recently upgraded to CS5 and am having the identical issues with making a PDF, small or Print quality, from InDesign. Background tasking seems to take over and I cannot even quit the document to clear things out, so I have to force quit.  I have gone to Software update, but no updates are noted.  The weird thing is that I noticed your posting is a year ago and surely there would have been an update by now.  InDesign version is 7.0.0.355; Acrobat Pro is 9.4.5.  Any thoughts....anyone?
                                                    • 303. Re: Problems making a PDF from Indesign CS5
                                                      We use a third-party plugin (part of a very expensive suite) that disables background PDFs, and haven't had a problem since. Adobe has not addressed this issue. Nor do they have any option for turning off background PDF in preferences. There are several non-Adobe options for doing this, though. Look on this forum; you will find some less expensive options to turn off background PDF, and I'm convinced that is the key to the whole thing.
                                                      • 304. Re: Problems making a PDF from Indesign CS5
                                                        Current version of CS5 is 7.0.4 and some of the problems with background export have been addressed.
                                                        • 305. Re: Problems making a PDF from Indesign CS5
                                                          Gdesigner6852
                                                          Solution for anyone who has not already discovered this...Courtesy of Bob L. Thanks Bob! Made my life a lot easier!
                                                          http://indesignsecrets.com/a-new-workaround-for-that-pesky-background-export-issue.php
                                                          • 306. Re: Problems making a PDF from Indesign CS5
                                                            GreyCatDot
                                                            OK, I upgraded to CS5 in March and started having this and various other problems. I did also upgrade to SnowLeopard at the same time. Yeah, I know late adopter. Figured all problems would be fixed by then. No such luck.
                                                            I am told by a mac tech friend that it doesnt happen to everyone but when it does, it is chronic. oy.
                                                            I have tried everything you all have suggested including dumping prefs for Acrobat, ID and QuickLook and turning Spotlight off. (something to do with Spotlight because other non Adobe stuff was being affected too). I even tried dumping master page guides. That worked. For now. I won 5.5 at a local meetup so I am really hoping this got fixed. The question is, did it get fixed with either 5.5 or Lion?
                                                            Thanks for your patience and help, yall.
                                                            Dot
                                                            • 307. Re: Problems making a PDF from Indesign CS5
                                                              designerBeans
                                                              Just curious -- do you have problems with new documents that you started from CS5 or just legacy documents?
                                                              • 308. Re: Problems making a PDF from Indesign CS5
        Gdesigner6852 Level 1
        I was also having problems with documents created in earlier versions as well. Are you talking about the exporting PDF problem?
        I know you said you have tried most of the suggestions, but have you tried installing that .jsx file from the link that I posted a while back? You copy and paste it into your InDesign start-up scripts folder and it creates on option under the file menu that will enable you to "disable background exporting". That worked for me.
        Vanessa L. Buono
        Graphic Designer
        Turning Stone Resort – Casino
        361.8205
        • 309. Re: Problems making a PDF from Indesign CS5
        GreyCatDot Level 1
        It does seem to be legacy documents.
        • 310. Re: Problems making a PDF from Indesign CS5
        GreyCatDot Level 1
        I didn't see your  post because of the 7 pages of debate going on off topic. I ended up finding it in InDesignSecrets and hopefully, it will at least fix my InDesign problem.
        Next up, the Text Edit and Illustrator problems.. I really do think it is a combination of that stupid background utility and SnowLeopard. For the people who think the background thing was useful, how long was it taking to make your PDFs? Before my upgrade, even 20 page docs only took 2-3 seconds to open in Acrobat from export.
        • 311. Re: Problems making a PDF from Indesign CS5
        TimeCruncher
        I've read that Adobe made exporting a pdf in Indesign CS5 to work in the background so you can go on to something else. Big mistake. I have to be able to see that pdf right away and continue on with my current job. CS4 made the pdfs so fast you didn't have to wait for it to process in the background. Unfortunately, I cannot go back to CS4. Tried, but I also have to deal with other people's work coming to me and it's in CS5. Tried making an .idml file so I could use CS4, but that takes as long as making a CS5 pdf.
        I hope they fix this cause I am losing a lot of time out of my day waiting on these pdfs. How about Adobe pay me for the time I'm losing.
        • 312. Re: Problems making a PDF from Indesign CS5
        Have you updated to the 7.0.4 patch? Did you read this whole thread and see the ways you can force export to the foreground?
        Aside from that, you should not be "waiting" for the PDF export. Set the options to display when it's finished and get on with your work. Unless the export is hung (and I haven't seen a single report of hanging export in months, so the 7.0.4 update seems to have solved most issues) it shouldn't be taking any longer than CS4.
        • 313. Re: Problems making a PDF from Indesign CS5
        TimeCruncher Level 1
        Thank you. I did find an answer as I read through the whole thread. I followed the instructions and now it is working fine. Thanks so much. However, that is something they should have built into CS5. Some people may have asked for the background exporting, but not all of us want it. It is so much faster without it, so I don't see why they want it going in the background. Puzzles me, but then I haven't walked a mile in their shoes. Thanks again!
        • 314. Re: Problems making a PDF from Indesign CS5
        Dubai_Dave Level 1
        my Acrobat recently updated and I lost lots of my presets and can't find them on my mac now - any idea why? Or any idea where I could download some from?
        • 315. Re: Problems making a PDF from Indesign CS5
        jdnorman Level 1
        Not the right thread to post questions about Acrobat - this thread is devoted specifically to PDF exporting issues in InDesign.
        • 316. Re: Problems making a PDF from Indesign CS5
        Dubai_Dave Level 1
        and further up the page people are talking about what I am asking about, so it all fits in. Mind your own business.
        • 317. Re: Problems making a PDF from Indesign CS5
        jdnorman Level 1
        I minded my own business when the thread-drifting started earlier. I'm suggesting that if you have problems with Acrobat, consider posting in an existing thread about Acrobat or creating a new one devoted to your specific issue. You will probably find your answer much more quickly.
        • 318. Re: Problems making a PDF from Indesign CS5
        People who create huge PDF files from huge InDesign files (I can imagine catalogues of several 100 pages) will need the background feature. But yes, It is surprising at first, when you are used the to old system. Switching the background task on or off should be an Option in the Options panel!
        BTW and easily off-topic: The build-in spellchecker does not know "InDesign" .
        • 319. Re: Problems making a PDF from Indesign CS5
        Dave,
        First off, I don't tolerate that sort of behavior in this forum. Either keep it polite, or keep it to yourself.
        As far as whether you are on or off topic here, I think you'll find that any posts referring to preferences were suggesting repalcing them, a standard troubleshooting technique for ID, and these suggestions were made BEFORE Matthew had tracked down the problem.
        This really is quite different from the loss of resets due to a program update. Updates remove thoses things stored in the InDesign SavedData file (which does not include presets) but I don't have any idea what you should expect to lose in Acrobat. I don't have any presets there to lose, but my cutomizarions of toolbars all seem to survive. I would say that this is really outside the expertise of most users here, and you really should move the question over to the Acrobat forum where you are much morte likely to learn waht is expected behavior and what you might want to be doing.
