You can actually remove the playbar from the entire presentation. Here's what I did.
I created a simple "shell" presentation of only a few slides with a standard look and feel that I would use on all the presentations requiring no playbar. In the theme editor, I set everything up as I wanted it (the playbar will show at first), I then did a save as with an appropriate name for the theme. Next, I published the presentation using the theme name. In the published data file, I opened the vconfig.xml file in notepad and altered the playbar line from
<uishow name="playbar" value="true"/> to <uishow name="playbar" value="false"/>
I then copied the entire published folder and placed it C:\Program Files\Adobe\Presenter 7\Themes
The next time I go to create a presentation, I go to the theme editor, choose the theme I created and you will notice that the playbar will not appear.
Hello,
I know this is an old post but I cannot find an answer and this post roughly replates to my question. I want to export a presenter presentation to PDF 'without' the bottom playbar. I have found information about changing the uishow name="playbar" options when exported for web use but nothing for when I want to export to PDF.
Any ideas?
Andrew
Andrew,
Set up your presentation as if for web use using the directions in my post above. So, you should have a folder on your C drive (C:\Program Files\Adobe\Presenter 7\Themes\name of your theme) in where you have changed <uishow name="playbar" value="false"/> in the vconfig.xml file. In Presenter, go to the Theme Editor and choose the newly created theme that does not have the playbar. Just to make sure that it took, publish to your desktop as if for wbt. As long as you do not see the playbar, then you can publish as pdf and the play bar should not appear. All of the other Presenter functionality should still be intact. You will not be able to see the published PDF unless you have at least Adobe Reader 9.
I just want to add to Kirkisbetter reply.
C:\Program Files\Adobe\Presenter 7\Themes\name of your theme ; contain theme which are preexisting or that we get with Adobe Presenter.
If you are using custom Theme i.e create theme from Adobe Presentre>Setting>Theme Editor. Then go to AppData folder in your system
For Win7 go to C:\Users\userfolder\AppData\Local\Adobe\Adobe Presenter\Themes\Custom Theme
For WinXp
C:\Documents and Settings\sshukla\Application Data\Adobe\Adobe Presenter\Themes\Custom Theme
There will be language.xml file. Edit it and add following tags:-
<layout> <uishow name="playbar" value="false"/> </layout>
Now publish it to pdf ; it will work for you
Thanks for the information. I will give it a go.
Is there anyway that acrobat can display a message advising that version 9 is required before a presentation will
play? I had 8 at first and it took me a while to figure out why I was just getting a white screen, something a general
user might not realise.
Andrew
Displaying acrbat version warning at time of publishing a presentation don't look suitable.
All the required softwares and specification are mentioned in system requirement page http://www.adobe.com/products/presenter/systemreqs/
