7 Replies Latest reply: Sep 22, 2011 5:43 AM by oeann RSS
    Netstream record ok - But need help to play the record after
    oeann Community Member
      Hello,
      I use amazon EC2 with fms.
      I can publish and record microphone and webcam, but after i want to play the record.
      I use the same link that i use for publish record but i cannot access to my record.
      I see my record in the admin consol.
      I think that i must activate the progessive download?
      But i dont know how and where.
      Can you help me please?
      Thanks a lot
      Oeann
        • 1. Re: Netstream record ok - But need help to play the record after
          SE_0208 Adobe Employee
          When you say "I use the same link that i use for publish record but i cannot access to my record." - what are you using - does that link have capabilty to playback the content.
          Say if you are publishing to say application called "myapp" with streamname as "mp4:mystream.f4v" (assuming you are publishing in F4V container) - you should be easily able to play it back using any simple playback client.
          If you dont have any client - you can use hosted Flash Media Playback client present here: http://www.osmf.org/configurator/fmp/
          You just need to make below changes
          Change Video Source to "rtmp://<amazonInstanceURI>/myapp/mp4:mystream.f4v" and in Advanced tab - just choose Recorded option as StreamType
          • 2. Re: Netstream record ok - But need help to play the record after
            thanks for you reply but not resolve my problem...
            i publish record with this code and is ok:
            nc = new NetConnection();
            nc.addEventListener(NetStatusEvent.NET_STATUS, nc_netStatusHandler);
            nc.client = this;
            nc.connect("rtmp://xxx-xx-xx-xx-xx.compute-1.amazonaws.com/music");
            ns = new NetStream(nc);
            ns.attachAudio(mic);
            if(webcam!=null)
                    if(webcamActivate==true)
                        ns.attachCamera(webcam);
            ns.publish("mp4:test.mp4", "record");
            and for replay my record i use flvplayback
            but cannot found my record...
            flvplayer.source = "rtmp://xxx-xx-xx-xx-xx.compute-1.amazonaws.com/music/mp4:test.mp4"
            flvplayer.play();
            in the past i was with influxis an i process with this step and work.
            then i am with fms with a server test and dont work for replay.
            i think that  i must activate progressive download but i dont know how in the config of server.
            and excuse me for my english i speak french....
            thanks to help me again
            Oeann
            • 3. Re: Netstream record ok - But need help to play the record after
              Nikhil Pavan Kalyan Community Member
              Thanks for using FMS on Amazon.
              Few quick checks :
              1. did you check that the recording is happening at /mnt/applications/music ? If not, make sure the dir has sufficient privileges to record.
              2. check the logs /mnt/logs to see if there are any errors
              • 4. Re: Netstream record ok - But need help to play the record after
                thanks for reply
                in my fms admin console i see my record when i start this with flash.
                After in my RDP connection i see my record in:
                C:\Program Files\Adobe\Flash Media Server 4\applications\music\streams\_definst_\test.mp4
                i dont understand why i can listen my record
                and i dont see any errors
                thanks a lot again to help me
                • 5. Re: Netstream record ok - But need help to play the record after
                  Admin console confirms the initiation of the record, but unless we go and find in the dir , its not totally confirmed.
                  Did you say you are able to listen to the audio of the record ?
                  Can you try with any other player that can help in viewing the recording ?
                  try this @ www.osmf.org/configurator/fmp/
                  Give the source as your stream and see if it can play.
                  Thank you
                  • 6. Re: Netstream record ok - But need help to play the record after
                    thanks i try with your online player you give me and always say buffering
                    then in up post i tell you that:
                    do you think is the problem? and if yes how and where i must activate this in my server amazon or RDP fms?.
                    Thanks a lot again
                    Oeann
                    • 7. Re: Netstream record ok - But need help to play the record after
                      please help me to resolve my problem....
