1. Re: Adobe: Please reopen this bug SDK-30917
Flex harUI Sep 20, 2011 10:44 AM (in response to RandomReado)Looks like Bill is watching the bug. Attach your simple test case and ask him to verify on 4.5.1
2. Re: Adobe: Please reopen this bug SDK-30917
S_Aleksey Sep 20, 2011 1:32 PM (in response to RandomReado)I am having exactly the same issue. Here is simple test case:
<?xml version="1.0" encoding="utf-8"?>
<s:WindowedApplication creationComplete="creationComplete(event)" xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/mx">
<fx:Script>
<![CDATA[
import mx.events.FlexEvent;
protected function creationComplete(event:FlexEvent):void
var timer:Timer = new Timer(1000);
timer.addEventListener(TimerEvent.TIMER, onTimer);
timer.start();
private function onTimer(event:Event):void
videoDisplay.source = null;
videoDisplay.source = "file:///D:\\test.flv";
</fx:Script>
<s:VideoDisplay id="videoDisplay"/>
</s:WindowedApplication>
The only workaround which works for me is to call System.gc() in the onTimer function. So it seems like for some reason garbage collector can't determine automatically that app runs out of memory.
Best Regards, Aleksey
3. Re: Adobe: Please reopen this bug SDK-30917
Flex harUI Sep 20, 2011 3:11 PM (in response to S_Aleksey)If system.gc() prevents the app from running out of memory, then it isn’t a memory leak, it means you are creating more allocations than the collector can collect. The GC is not a separate process/thread. It runs on occasion and can fall behind.
4. Re: Adobe: Please reopen this bug SDK-30917
S_Aleksey Sep 20, 2011 10:44 PM (in response to Flex harUI)The problem is that I set source property not in loop but on timer with interval. I tried to set large interval like 20 seconds and still for some reason garbage collector can't find time to collect memory.
5. Re: Adobe: Please reopen this bug SDK-30917
Flex harUI Sep 20, 2011 11:37 PM (in response to S_Aleksey)Make sure you update the bug with your test case and latest findings.
6. Re: Adobe: Please reopen this bug SDK-30917
RandomReado Sep 21, 2011 12:32 AM (in response to Flex harUI)My test case was an example of a playlist - like on YouTube you can flick from video to video, typically this was doing the same thing. Setting the Interval to something higher produces the same result.
In my real-life application, users open the application and play a video (20 minutes long or so), then another (same length), and another, etc... A few hours later the application crashes and according to Task Manager the application is "not responding" and is using over 1GB of memory at that point in time.
7. Re: Adobe: Please reopen this bug SDK-30917
RandomReado Sep 21, 2011 12:37 AM (in response to Flex harUI)Alex, I commented on the bug closure over 2 weeks ago but the bug remains closed. So I created a cloned bug thinking it was being ignored but nothing's been posted on that bug either. Can you find out if anything is being done about this please?
The cloned bug is here: https://bugs.adobe.com/jira/browse/SDK-31483. I have cross referenced this thread in the comments.
8. Re: Adobe: Please reopen this bug SDK-30917
Jens Chr Nov 29, 2011 7:07 AM (in response to RandomReado)I can confirm that this bug exists. Had to replace all instances of the video component with a custom AS3 class. Now all my apps will run reliably...
9. Re: Adobe: Please reopen this bug SDK-30917
Flex harUI Nov 29, 2011 11:06 AM (in response to Jens Chr)This is supposedly fixed in 4.6, which should go live sometime before the end of the day on the west coast.
