Show 2 replies
1. Re: How to stabilize parts of a multi-cam sequence ?
ExactImage Sep 21, 2011 2:28 AM (in response to Macphil11)Have you cut the clip each side before sending it?
You could try making a subclip..... though I haven't tried it so I don't know for sure that would work - it's worth trying through.
An alternative is to render the part of the clip to a file, stabilize that then use the replace footage to replace the footage on the multicam sequence. This is more hassle, but at least you have an actual file that is stable rather than relying on dymanic linking (which has failed me a couple of times).
2. Re: How to stabilize parts of a multi-cam sequence ?
Fuzzy Barsik Sep 21, 2011 4:46 AM (in response to Macphil11)Hope it helps.
