2 Replies Latest reply on Nov 4, 2011 11:54 AM by Jaap H
    Error during build
      I am new in premier pro cs4 sdk. I give the following error when build the  SDK_Custom_Importpipl &  SDK_Custom_Import.cpp
      Error    3    error LNK1104: cannot open file 'C:\Program Files\Adobe\Adobe Premiere Pro CS4\Plug-ins\Common\\CustomImporterSDK.prm'    E:\snehal\Premiere Pro CS4 r1 SDK Win\Projects\SDK_Custom_Import\LINK    SDK_Custom_Import
      what is right solution for the above problem
      please help me!!!!!!
        • 1. Re: Error during build
          Petro Gretchanei
          Make sure that .prm file is not used by some other app. For example, you might have Preimere Pro running that has this plugin loaded and, when you try to rebuild the plugin, VS probably has to delete old .prm file and write new one. Well, it can't, since it is in use.
          • 2. Re: Error during build
            Jaap H Level 1
            You have to set an Environment variable called PREMSDKBUILDPATH:
            On Windows, to specify where you want the built plug-ins to go, set a user environment variable (right-click My Computer > Properties > Advanced > Environment Variables > User variables) called PREMSDKBUILDPATH to the desired path (e.g. "C:\Program Files\Adobe\Common\Plug-ins\CSXX\MediaCore"), and re-log in so that the variable will be set. In the Visual Studio Property Pages for each SDK project, this path is the base path for the Output Directory.
