I'm trying to set styles in RH8 (especially multilevel lists) and cannot find the logic.
I create the style in RH, but cannot get enough control over indent and spacing. So I'm editing the CSS and every little change has unexpected results.
For example in the 2nd level, I don't want numbering so I changed the line to:
x-lvl-2-type: ;
and RH inserts upper case letters to begin each line.
Any help?
One more thing - I just noticed when I make a change (via the CSS) to the style mention above, a totally unrelated style gets messed up.
Take a look at Lists on my site.
Thanks. I looked at your site. But I think I have everything correctly defined.
Here's the style:
rh-list.FTProcSubStep {
x-lvl-3-type: lower-roman;
x-lvl-3-format: "<x>&c";
x-lvl-3-margin: 40px;
x-lvl-4-type: decimal;
x-lvl-4-format: "&o<x>&c";
x-lvl-4-margin: 60px;
x-lvl-5-format: "&o<x>&c";
x-lvl-5-margin: 80px;
x-lvl-6-type: lower-roman;
x-lvl-6-format: "&o<x>&c";
x-lvl-6-margin: 100px;
x-lvl-8-type: lower-alpha;
x-lvl-8-margin: 140px;
x-lvl-7-format: "<x>.";
x-lvl-7-margin: 120px;
x-lvl-9-type: lower-roman;
x-lvl-9-margin: 160px;
x-lvl-1-type: lower-alpha;
x-lvl-1-format: "<x>";
x-lvl-2-format: "<x>";
x-lvl-1-margin: 17.5pt;
x-lvl-1-p-class: bodytext;
x-lvl-1-p-tag: p;
x-level-count: 9;
x-lvl-2-type: ;
x-lvl-2-margin: 40px;
x-lvl-2-p-class: bodytext;
x-lvl-2-p-tag: p;
The lvl-1 does give a lower case letter. But lvl-2 gives an upper case letter instead of the no numbering that I want (
x-lvl-2-type)Copy link to clipboard
Hard to tell whether your RoboHelp Multilevel lists are correctly defined in the css. RoboHelp Multilevel Lists are not HTML lists and the style in your CSS is a RH interpretation and not CSS. So it's not that strange that the styles don't make sense I played around with the css but I gave up after a couple of minutes.
For RoboHelp Multilevel Lists, use the built-in style editor unless you want to be pulling your hear out in frustration. See Peter's site or some good info on RoboHelp Multilevel Lists and how to set them up with the style editor.
Greet,
Willam
x-lvl-4-format: "";
At whatever level insert nothing between the quotes. You will have to do that manually because of a bug. That is what should happen if you select None but it doesn't.
Whenever you edit a style using the built is editor, it is likely to change that to something else so check what happens.
OK. This isn't funny anymore.
I'm trying a new tact and it's just as bad. I need to set up styles that enable me to have multi-step procedures with a numbered/lettered para (action) followed by an un-numbered/unlettered para (result). Each with descending levels of indentations.
So now I've set up a multilevel list that produces this:
3. Action
a Action
i Action
ii Action
b Action
i Action
ii Action
4. Action
Then I created simple para styles that will insert results (properly indented) after every action. But apparently RH will not allow me to insert a para style inside a multilevel list! Is this possible!?! I simply want to get the following:
3. Action
a Action
Result
i Action
Result
ii Action
Result
b Action
Result
i Action
Result
ii Action
Result
4. Action
So your list starts something like this
1] Item
a] Item
b] Item
2] Item
but now you want to insert some non list paragraphs.
Put the cursor after b] Item and press Enter.
Now click the numbering icon and that line is no longer a list. You can add whatever you want.
RPHOX 2003
Working now?
Yes, all is working now. Thanks.
I just wonder what people do who don't know HTML. Not a very user-friendly environment.
Thanks again for all your help.
LOL, post on the forum of course
Greet,
Willam
