I have a form I built wherein I am binding several fields to one cfinput and hitting a cfc I built that pulls data from a web service. I am struggling in figuring out how to get the fields to fill in with the binding value once I click a button. Here's the scenario...the end user fills in the field, clicks a button and several other fields get filled in from the cfc that hits the web service. I have tried the following to no avail...
<cfform id="myForm" format="html">
<cfinput type="text" name="reporttype" id="reporttype" value="BASIC">
<cfinput type="text" name="vin" id="vin" value="xxxxxxxxxxxxxxxxx"><br />
<cfinput type="text" name="modelYear" value="" size="30" bind="cfc:cfc.vinlookup.getYearvin(argVIN={vin},argReporttype={reporttype})" /><br />
<cfinput type="button" value="getvin" name="getvin" id="getvin">
</cfform>
I have even tried playing with the cfajaxproxy tag and the @click event. I feel like I am close. If someone could educate me/point me in the right direction, I would appreciate it.
~Clay
When I add the @click in the above bind attribute, it works when I click in the appropriate fields, but I cannot seem to figure out how to run the bind when clicking the button.
ok...I figured it out and thought I would post my solution in case someone else runs into this issue...
(my solution is based of of this link)
cfajaxproxy tag to tie cfc to page via JSON
<cfajaxproxy cfc="proxy" jsclassname="proxy" />
Script that runs the method within the cfc and uses the setCallbackHandler function to return the result. The we can set the result equal to the value utilizing the DOM.
<script>
function getYearvin(source) {
var instance = new proxy();
instance.setCallbackHandler(getYearvinSuccess);
instance.getYearvin(source);
function getYearvinSuccess(result) {
document.getElementById('year').value = result;
</script>
Here is the form...
<input type="text" name="source" id="source" value="" />
<button name="vinDecode" onClick="getYearvin(getElementById('source').value)">Get Year</button>
<br><br>
<input type="text" name="year" id="year" value="" />
FYI...I wrote a quick blog post concerning this...http://webolutiondesigns.com/blog/ajaxcfcs-json-and-other-geeky-stuff/
