I upgraded from Flash Builder 4.5 to 4.5.1. When I went to import my projects I was warned that the workspace was created in an older version of FB and that I should migrate the projects to a new 4.5.1 workspace. Instructions are here:
http://kb2.adobe.com/cps/899/cpsid_89996.html
Step 1, "Export the project as an FXP file" fails. Dialog looks like:
Not much detail.
It does this whether or not "Validate project compilation" is checked.
So I shouldn't run the projects in the existing workspace in the new version of FB, and I can't migrate the projects to a new workspace in the new FB. How do I win here? The errors are not listed anywhere? What do I fix?
Can you send the error log (.log file), which you can find in the .metadata folder in your workspace directory.
Though the preferred method is exporting, as a workaround, you can try copying the projects from that workspace directory to the new workspace directory.
-Sunil
-Sunil
That's the route I went.
I am having the same problem. The error seems to be related to .fxpProperties. Is there a way I can fix this? - Thanks Rob
The error log file is:
!ENTRY com.adobe.flexbuilder.project 4 43 2011-12-05 10:03:22.741
!MESSAGE Error reading persistence file C:\Documents and Settings\Rob\Adobe Flash Builder 4.5\db-mfesan\.fxpProperties
!STACK 0
com.adobe.flexbuilder.project.persist.PersistenceException: Error reading persistence file C:\Documents and Settings\Rob\Adobe Flash Builder 4.5\db-mfesan\.fxpProperties
at com.adobe.flexbuilder.project.persist.PersistableSettings.readPersistenceFile(PersistableSettings.java:170)
at com.adobe.flexbuilder.project.fxp.FXPProperties.<init>(FXPProperties.java:246)
at com.adobe.flexbuilder.project.fxp.FXPProperties.readFXPProperties(FXPProperties.java:203)
at com.adobe.flexbuilder.project.fxp.FXPProperties.getFXPProperties(FXPProperties.java:183)
at com.adobe.flexbuilder.project.fxp.FXP.buildFXP(FXP.java:273)
at com.adobe.flexbuilder.exportimport.exportwizard.AbstractExportWorker.createFXPArchive(AbstractExportWorker.java:157)
at com.adobe.flexbuilder.exportimport.exportwizard.AbstractExportWorker.createArchive(AbstractExportWorker.java:89)
at com.adobe.flexbuilder.exportimport.exportwizard.ExportProject.export(ExportProject.java:63)
at com.adobe.flexbuilder.exportimport.exportwizard.ExportWizard.exportProject(ExportWizard.java:340)
at com.adobe.flexbuilder.exportimport.exportwizard.ExportWizard$2.execute(ExportWizard.java:292)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1975)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1008)
at com.adobe.flexbuilder.exportimport.exportwizard.ExportWizard.exportProjectContents(ExportWizard.java:300)
at com.adobe.flexbuilder.exportimport.exportwizard.ExportWizard.performFinish(ExportWizard.java:239)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:811)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:430)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at com.adobe.flexbuilder.exportimport.menuactions.FlexProjectExportAction.run(FlexProjectExportAction.java:62)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.java:108)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Caused by: org.eclipse.core.runtime.CoreException: Could not read XML document
at com.adobe.flexbuilder.project.internal.FlexProjectCore.createCoreException(FlexProjectCore.java:981)
at com.adobe.flexbuilder.util.XMLUtil.toDocument(XMLUtil.java:213)
at com.adobe.flexbuilder.util.XMLUtil.toDocument(XMLUtil.java:180)
at com.adobe.flexbuilder.project.persist.PersistableSettings.readPersistenceFile(PersistableSettings.java:157)
... 57 more
Caused by: org.xml.sax.SAXParseException: Content is not allowed in prolog.
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(Unknown Source)
at javax.xml.parsers.DocumentBuilder.parse(Unknown Source)
at com.adobe.flexbuilder.util.XMLUtil.toDocument(XMLUtil.java:211)
... 59 more
