Hi all,
i'm trying to set up the testdrive tutorial for flex mobile project, with flash builder 4.5
and php data.
I've uploaded the files on my remote web space (e.g. http://mywebsite.org, and the
test file is http://mywebsite.org/TestDrive/test/test.php... and it works
correctly)... But when i'm setting properties of the project, i don't know what
to write into the web root and root path fields... I thing root path is simply
http://mywebsite.org... and whatever i write in the other fields (output folder
too) i have errors when i click on "validate configuration"...
What should i put into those fields? is zend framework (and gateway.php)
strictly necessary?
As you can see... i'm a bit confused....
Many thanks for any help
Bye
Alex
I thought it was a simple question...
No advice?
