I am trying to access some .NET objects and I keep getting the error "Class System.Web.Services.WebService not found in the specified assembly list." I am able to access an object in the .NET core DLL so my .NET setup seems ok. I've tried a number of assembly list variations in the CreateObject call. I've also tried adding assembies to the JNBDotNetSide.exe.config file. But I continue to get the error. I've done some googling but haven't found anything that has helped...
Ok so maybe I'm an idiot. It turned out that I was trying to access a .NET 4.0 object and my CF wasn't set up to support 4.0. I had to update the jnbridge\jnbproxy.exe.config file to add an entry for 4.0 then restart CF. Now it's working.
I'm assuming that you've seen this thread, but just in case it slipped through your google search:
