4 Replies Latest reply: Sep 24, 2011 5:16 AM by Noel Carboni RSS
    Understanding Camera RAW with JPEGs
    Unsigned Code Labs Community Member
      I usually work on the design end, hence I rarely work (professionally) with files straight-from-camera. I get the stuff after the photographers are done with it.
      However, that is slightly changing and so I have a question about the Camera Raw plugin in Photoshop. In particular, processing JPEG images with it.
      If I understand correctly, it does not actually modify the JPEG image itself, but merely saves the correction information as metadata in the JPEG file, which is then re-constructed when the JPEG is re-opened.
      This would (assuming I understand it properly) make it a "safe" way of tweaking JPEGs as unlike most JPEG operations, no resave/quality-loss is occurring. Only the metadata is changing.
      Am I correct or have I horribly misunderstood this process?
        • 1. Re: Understanding Camera RAW with JPEGs
          Jeff Schewe Community Member
          There a forum for Camera Raw here...
          Your understand is somewhat correct...if you open a JPEG in Camera Raw and hit Done, then the adjustment settings are saved in .xmp metadata inside the JPEG and the original data is not altered. However, only Camera Raw, Bridge, Photoshop & Lightroom can "see" those changes...in oder to have the settings actually applied you must process the JPEG through Camera Raw into Photoshop or in Lightroom.
          • 2. Re: Understanding Camera RAW with JPEGs
            Noel Carboni Community Member
            Me, I'd open the JPEG without using Camera Raw, convert to 16 bits/channel, do what I want in Photoshop proper, then save as .PSD.  Voila, no further loss occurs after the initial decompression.  Safe because nothing is being written back to the JPEG file.
            -Noel
            • 3. Re: Understanding Camera RAW with JPEGs
              Actually Noel, processing a camera JPEG through Camera Raw has a lot of technical pluses...ACR takes the camera JPEG (regardless of color space) and does all it's processing in ProPhoto RGB Linear color space. I've found that ACR does a better job of processing camera JPEGS than doing the same work in Photoshop even in 16 bit.
              • 4. Re: Understanding Camera RAW with JPEGs
                I can appreciate that - my own plug-ins all do their work in linear space as well for the advantages thereof.  However, it's not as if one can't get good results with the normal Photoshop tools, which for some reason seem to be out of favor...  One can convert to a linear profile to work on it in Photoshop proper, for example (though one has to craft or find a linear profile to use for that, as none is provided by Adobe).  I do my astroimage processing that way.
                I might change my workflow to involve Camera Raw where JPEGs are concerned IF Camera Raw could be set to write its metadata back to a sidecar file or the central database instead of rewriting the JPEG file.  I understand that it is not rewriting the actual image data, but I just don't want it writing back to my JPEGs at all.
                -Noel
