33 Replies Latest reply on May 2, 2017 10:06 AM by paul_holden
    Cannot Resize Too Large Print Dialog Box
    PutridBeast
      When trying to print using Reader X, the print dialog is huge and the "OK" button extends off the bottom, making it inaccessible.  I have tried resizing the print box but the handles that appear on the edges will not adjust the size of the box.  This happens no matter the size of the Reader window with which I am working.
      Is anybody else running into this problem? Any idea how to fix it?
      I am using a screen resolution of 1024 x 768.
      Thanks.
        • 1. Re: Cannot Resize Too Large Print Dialog Box
          Earnest User
          I have the same problem too.  Did not have the problem with Reader v. 9.4.  Please advise how to adjust size.  Thanks.
          • 2. Re: Cannot Resize Too Large Print Dialog Box
            Dave Merchant MVP & Adobe Community Professional
            What operating system are you using, and do you have any custom settings applied to the display (increased font size, large taskbar, etc.)?
            The standard Print dialog on Windows Vista/7 is just under 730 pixels high, so it should *just* fit onto a 1024x768 screen with a default Windows taskbar.
            • 3. Re: Cannot Resize Too Large Print Dialog Box
              Bey64
              I am running the 768 height and cannot get to the ok button in the print box.  Please let me know if there is a solution.
              • 4. Re: Cannot Resize Too Large Print Dialog Box
                Ervil Twink
                I am having the same problem to. Microsoft had no answers and said it was an Adobe problem. The only print dialog box I have problems with is the Adobe print dialog box and the one that USPS uses on their click and ship site. They had no answers either and said to contact Microsoft because I was using Windows 7 64 bit. I begin to wonder if the 64 bit Windows that I am running is causing the problem. I don't see anybody else having this problem until I found this site a few minutes ago. One person mentioned how you cannot resize the window, when I try to resize it it will jump down a 1/2 inch or so and then return back to the same spot. If you try it on the sides or corners it does nothing. I can print because if all you want to do is print 1 copy just hit the return button and it will start printing. I use a Canon MX870 printer and that is the dialog box that Windows uses for all printing tasks except when you want to print PDF files, etc. that are created with Adobe products. I never had any problem with any of the other versions and I think I might load down the one before the X. I have been on the Microsoft site and asked all these questions and not one high paid Microsoft employee could help with the problem and they acted like I was from Mars or something when I brought up the subject. Isn't there an Adobe tech that can help with this on this forum? Please help, Ervil Twink
                • 5. Re: Cannot Resize Too Large Print Dialog Box
                  The standard Adobe Reader X print dialog in Windows 7 should be as shown below - 695 x 728 pixels.
                  It cannot be made smaller as the contents of Acrobat and Reader X dialog boxes do not reflow, but at the default size it does fit on a 1024x768 display.
                  If your dialog box is a different size or shape, please post a screenshot and detailed system information, in particular if you have made any changes to the Windows accessibility and font size settings.
                  • 6. Re: Cannot Resize Too Large Print Dialog Box
                    Ervil Twink Level 1
                    Click on this link and there is a screenshot of my printer dialog box that was posted on a Windows forum site that I had asked the same question as this original person to this post did. I posted a small shot and a larger shot. You can also see the other answers to the question which there were none as far as I was concerned.
                    http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_programs/cannot-see-bot tom-buttons-of-print-dialogue-box-in/2ef12505-bf43-e011-90b6-1cc1de79d2e2
                    • 7. Re: Cannot Resize Too Large Print Dialog Box
                      1blrjohn
                      The solution - with Windows 7 - on your desktop, right click and select "Screen Resolution"
                      Then look for link near bottom "Make text and other items larger or smaller" and click there.
                      The default is 100%, but I had mine set at "Medium" - 125% to make reading easier.
                      Now, to correct the issue at hand, I have mine set to "Custom" at 105%  - and life is good.
                      • 8. Re: Cannot Resize Too Large Print Dialog Box
                        Ervil Twink Level 1
                        I set mine at 90% and it doesn't make any difference. Changing the resolutions, screen percentage, etc. does not solve the problem of the bottom buttons hiding themselves behind the bottom task bar. Click on the link that I posted in one of the other replies and you can see what I am talking about on how the bottom buttons are blocked by the task bar on the bottom of the screen. Yesterday I decided to uninstall Reader X and re-install Reader 9.4 and the print dialog box is about 2/3 the size and all the buttons on the bottom of the dialog box are visable. The program works like it should. Now I wonder if I should try and reinstall Reader X and see if there had been a problem when it installed originally? I would like to know what is causing this on some computers and some operating systems? It doesn't seem to make a difference if the circumstances with each computer are not the same?
                        • 9. Re: Cannot Resize Too Large Print Dialog Box
                          Xirad
                          Has this never been resolved?  I'm having the same issue on WinXP and Adobe Reader X   AND  Adobe Acrobat Pro X.  But my dialog boxes are HUGE.  So huge you can't read anything.  The same thing happens with any security error pop-ups, the Preferences dialog and any warnings that I've not saved my changes, etc.  All I can do is hit ESC or Enter and hope that whatever is selected is what I want.
                          I have the full Adobe Web Creative Suite 5.5 and all the rest of the products - Dreamweaver, Photoshop, etc. behave correctly.
                          • 10. Re: Cannot Resize Too Large Print Dialog Box
                            Ervil Twink Level 1
                            Hello Xirad. I downloaded the 9.4 version of Adobe Reader and got rid of the X version and I have had no problems since except Microsoft keeps telling me daily that there is updates to this software available and would I like to update this at this time. I have to say know to that and say yes to the rest of the updates available of all the rest of the programs on my computer. Pain in the *** but at least I can print things out now. I have no clue what is causing it and why just a few of us is having the problem? Is it the computer we are using or what side of the equator we are located, etc. If anyone has the answers to this old problem, like maybe someone from Adobe???? I would be more than happy to download the X version again. Ervil
                            • 11. Re: Cannot Resize Too Large Print Dialog Box
                              Xirad Level 1
                              What's frustrating is this problem is with a PURCHASED product, not just the free Reader.
                              I too did what everyone else is doing and uninstalled Reader X and instead installed Reader 9.  Print, Preferences and the rest of the dialog boxes work fine.  Though now I have an error where if I just launch Reader I get the app up but a gray background.  After about 30 seconds I get a popup error saying The File Was Not Found.  I think it's that little shortcut help window that's supposed to pop up.
                              BTW, there are still security updates for 9 and you should install those - even as recent as a few days ago.  I think for version 10 it specifically asks you if you want to upgrade.  Under Preferences, Update you can turn off the update check too.
                              If I have time I'm going to call Adobe and book a case, since again, I PAID for Acrobat Pro X.
                              Xirad
                              Here's what Preferences looks like in Acrobat Pro X:
                              • 12. Re: Cannot Resize Too Large Print Dialog Box
                                Ervil Twink Level 1
                                Hello Xirad, you would have thought someone from Adobe would have gotten back to me, I email them over 6 months ago and never received any kind of communication in return. Oh well, the 9.4 version is still working fine so I guess I can’t complain too much. How come not everybody has the same problem? I am running an IBM Lenovo laptop, what are you running?
                                • 13. Re: Cannot Resize Too Large Print Dialog Box
                                  Counterdoc2
                                  I am having the same problem on WinXP with Adobe Reader X... Version 9 works fine btw. It has nothing to do with the screen resolution (i use the default settings).
                                  • 14. Re: Cannot Resize Too Large Print Dialog Box
                                    Allta Media Adobe Community Professional
                                    On computers with low resolution, such as 800 X 600, the Print and Cancel buttons can be off the screen. The free 10.1.3 update to Reader and Acrobat addresses this issue. You can install this update automatically from within Reader and Acrobat. If you cannot update at this time, do any of the following:
                                    • Drag the scroll bar on the right side of the Print dialog box down to access the buttons.
                                    • To print, press Enter or Return.
                                    • To cancel, press Esc.
                                    This information has been taken from the following knowledgebase article Printing questions | Acrobat, Reader 10.1.2 or later.
                                    • 15. Re: Cannot Resize Too Large Print Dialog Box
                                      PutridBeast Level 1
                                      I solved all of my Adobe Reader frustrations, including this one, by
                                      installing PDF-Xchange [
                                      http://www.tracker-software.com/product/pdf-xchange-viewer] and making it
                                      my default .pdf software.  I have not had a problem since and am very happy
                                      with the additional functionality provided by this lightweight software.
                                      • 16. Re: Cannot Resize Too Large Print Dialog Box
                                        Counterdoc2 Level 1
                                        I solved the problem...
                                        The windows default font was missing. After reinstalling the standard fonts it worked fine!
                                        • 17. Re: Cannot Resize Too Large Print Dialog Box
                                          Thanks so much for letting us know how you solved your issue.
                                          • 18. Re: Cannot Resize Too Large Print Dialog Box
                                            j1023walk
                                            Hi Lori,
                                            With all due respect, this is not an acceptable response.  I am running Windows 7 at 1280 x 800 resolution with version 10.1.4 of Adobe Reader, and the print window is still too big for my Viewsonic 22" screen.  Adobe needs to get their act together and FIX THIS!  If you need an example, just run Microsoft Word's Print Window.  Takes up less than 2/3rds of the screen, and has all the information needed in this window to print a quality document.  No excuse for Adobe.
                                            John
                                            • 19. Re: Cannot Resize Too Large Print Dialog Box
                                              John this is a user-to-user forum and I'm just passing along suggestions. You can feel free to submit your issue here at this link Feature Request/Bug Report Form.
                                              • 20. Re: Cannot Resize Too Large Print Dialog Box
                                                trickle Level 1
                                                Here is the answer that worked for me:
                                                Acrobat and Reader now take advantage of Hi-DPI monitors and can scale the user interface to 200%. This is automatically enabled using system settings and can be customized by choosing Preferences > General > Scale for screen resolution. The value is set to Auto by default, but it can be forced to 100% or 200%. Other items such as the font size, menu items, and drop down lists are controlled by the user’s system control panel rather than application’s preferences.
                                                11.0.07 scaling settings options and behavior are as follows:
                                                • Auto
                                                  • For settings up to 150%, display the UI at 100%
                                                  • For settings 150% or higher, display the UI at 200%
                                                • 100%
                                                • 200%
                                                • 21. Re: Cannot Resize Too Large Print Dialog Box
                                                  mwawak
                                                  My windows default font was not set. After setting it and restarted Reader my issues went away.
                                                  • 22. Re: Cannot Resize Too Large Print Dialog Box
                                                    cjestel Level 1
                                                    I have a larger resolution, but still had to scroll down to hit print.  That in itself wasn't too annoying, but the printer was autoselected, so when I scrolled with my mouse it would change the printer I was using.
                                                    This resolution worked for me and I think will work for a lot of you as well.  Open reader, and then go to edit->preferences.  Click on General on the left hand side. Change "Scale screen resolution (requires restart):" to 100%, then scroll to the bottom and hit OK.  Close reader, and then re-open it.  The print dialog box when I went to print after that was a normal size.
                                                    • 23. Re: Cannot Resize Too Large Print Dialog Box
                                                      sp4753 Level 1
                                                      Not one of these "solutions" is satisfactory. However I did find a real solution somewhere that fixed the problem properly without having to mess with the screen resolution. Then I uninstalled Adobe Reader XI because another of its features was irritating me to death. Like PutridBeast above, I switched to another pdf software (not PDF-Xchange but thanks for the tip - it might be better than the Nuance product).
                                                      Unfortunately Nuance PDF Standard has its own irritating features so I then re-installed Adobe Reader XI to use only when I wanted a certain feature. So now I have the Adobe Reader huge print dialog box all over again!
                                                      I have searched through all my internet history to try and find the solution I found before, but with no success.
                                                      Isn't there someone out there who has found the same solution I found to this 4 year old problem?
                                                      • 24. Re: Cannot Resize Too Large Print Dialog Box
                                                        sp4753 Level 1
                                                        LoriiAUC, this is not the correct answer. PutridBeast has a high resolution monitor. Your answer assumes he has a low-res monitor.
                                                        • 25. Re: Cannot Resize Too Large Print Dialog Box
                                                          sp4753 Level 1
                                                          Sorry, Dave. EarnestUser didn't get a satisfactory reply from you, did he? Where did he go? The problem is nothing to do with screen resolution.
                                                          • 26. Re: Cannot Resize Too Large Print Dialog Box
                                                            sp4753 Level 1
                                                            Dear Bey64
                                                            You didn't get an answer either. If you would still like to use Adobe ReaderXI occasionally, check out this spot from time to time and you might find an answer. I am determined to find one.
                                                            Regards, Shirley
                                                            • 27. Re: Cannot Resize Too Large Print Dialog Box
                                                              sp4753 Level 1
                                                              Dear Dave
                                                              The print dialog box can indeed be made smaller. I have done it and it worked permanently. I didn't have to change my screen resolution.
                                                              It would be lovely if you would help me to find the solution I found previously. Then together we could help all the people on this page and the thousands of others who have no doubt given up on trying to find a solution.
                                                              Regards, Shirley
                                                              • 28. Re: Cannot Resize Too Large Print Dialog Box
        sp4753 Level 1
        Dear 1blrjohn
        How can life be good when everything else on your computer is now too small?
        Fiddling with screen resolution is not eh solution.
        Regards, Shirley
        • 29. Re: Cannot Resize Too Large Print Dialog Box
        sp4753 Level 1
        Dear Ervil Twink
        You are quite right. Changing screen resolution does not fix this problem.
        How can this forum regard the question as resolved when it clearly isn't?
        Regards, Shirley
        • 30. Re: Cannot Resize Too Large Print Dialog Box
        sp4753 Level 1
        Dear Xirad
        Yes, this problem has never been fixed by Adobe. Sadly I found a solution and then lost it.
        Regards, Shirley
        • 31. Re: Cannot Resize Too Large Print Dialog Box
        sp4753 Level 1
        Dear LoriAUC
        Your solution doesn't work. First you have to tick any boxes at the top of the dialog box that you want to tick. Then you have to drag the entire dialog box up so the top is off the screen. Now you can see the bottom of the box so you can click on Print.
        This takes about 30 seconds instead of 3 seconds. Not satisfactory in the computer age.
        Regards, Shirley
        • 32. Re: Cannot Resize Too Large Print Dialog Box
        Fred2179
        I've noticed this silly problem since Reader DC was forced on my a few weeks ago.  (Guess that's what happens when you get something for free.)  I'm using version 2015.008.20082.  When it 'updated' to this version, my "print" button was off the bottom of the screen - my monitor is HD and when I checked, the visible window was 1047 pixels deep to just above the "Print" button.
        Yes, the elevator/scroll bar lets me go to the button, but it is a bit annoying.
        Looking at all the suggested solutions, I checked for a Preference to set scaling - no dice.  It's been removed in my version.  I had 'auto detect' set and I switched it to 'no scaling'.  That solved the problem, but everything is now tiny.  I prefer the view when scaling is set to 'auto deterct'.  But then I can't see the "Print" button.
        This is REALLY annoying.  Whoever invented 'auto detect' scaling forgot to re-scale the Print dialog !!!  Adobe - please fix it.
        • 33. Re: Cannot Resize Too Large Print Dialog Box
        paul_holden
        Experienced the same issue and this resolved it. In Adobe v.11 go to: Help > Repair Installation (*Restart required)
