Hi dave.r and I suppose I should also say: welcome to our
community. Sorry I forgot that.
Wow, I actually fired up my copy of RoboHelp for Word to
check this!
Okay, note that at the bottom of your RoboHelp application,
you see a folder labeled "Single Source Layouts". If you right
click a layout, you have the option to duplicate it. So to copy the
output file to multiple locations, you now have multiple copies of
the layout. In the properties of each of the layouts, you specify
different folders and file names.
Now comes the fun part. You click File > Batch Generate...
and just place check marks next to the desired layouts. Once you
select all the layouts you want, you click the Generate button and
off you go.
There is one thing I'm not totally sure about with this. If
you are generating multiple copies of the same layout, but just to
different folders, I'm thinking you end up actually compiling the
.HLP two or more times, whereas in the former paradigm it was more
efficient, as you simply compiled a single time and copied to the
desired folders.
Now if you really want to, you should be able to accomplish
the compile once copy many by simply creating your own batch file
to do the heavy lifting of the copying.
Cheers... Rick
