Hi, i have the filed with smalldatime format. from my query, i have: between '#TimeFormat(form.d__stage_time_startTime, "HH:mm")#' and '#TimeFormat(form.d__stage_time_endTime, "HH:mm")#' resutls A: Correct between '10:00' and '12:00' But when i added cfqueryparam and I didn't get the same results and it passing something below which was not Correctted. i've try cf_sql_time or cf_sql_timestamp but none of them work just like the one i have from results A. resutls B: Parameter #1(cf_sql_time) = {ts '1899-12-30 10:00:00'} Parameter #2(cf_sql_time) = {ts '1899-12-30 12:00:00'} what can i do in cfqueryparam to get the same results as passing like from results A? thanks
I assume that in your query, you are using a database function of some sort to extract the time portion of the datetime field.
Timeformat returns a string, not a time object. The first thing I would do is to use CreateTime instead. I would also use cfsqltype="cf_sql_time". Then it should work properly.
create time?, it takes 3 parameters, what can i do here?
thanks
If you strictly want time values, then you shouldn't be mixing times with datetimes. Why not use CHAR as the datatype? Here is an example:
<cfset t = "12:34">
<cfquery name="q" datasource="myDSN">
insert into myTBL(timeCol) values(<cfqueryparam cfsqltype="cf_sql_time" value="#t#">)
</cfquery>
This would work when the field timeCol has datatype CHAR(8) or TIME (I am on MySQL). The time would then be stored as 12:34:00.
