1. Re: Project stops on school computer
Harm Millaard Sep 28, 2011 12:10 AM (in response to Scubapete70)Yes.
But I won't tell if you don't tell what is needed. Some suggestions... and answer at least the 16 questions at the end of the Wiki article.
2. Re: Project stops on school computer
JSS1138 Sep 28, 2011 10:53 AM (in response to Scubapete70)What operating systems are being used for which computers?
3. Re: Project stops on school computer
Bill Hunt Sep 28, 2011 12:22 PM (in response to Scubapete70)Along with the answers to the questions above, be sure to give the full specs. of the external HDD and its connection.
Good luck,
Hunt
4. Re: Project stops on school computer
Todd_Kopriva Sep 28, 2011 3:49 PM (in response to Scubapete70) -
5. Re: Project stops on school computer
JEShort01 Sep 28, 2011 4:04 PM (in response to Scubapete70)Scubapete,
Yes, I have some ideas if the following two assumptions are both correct:
1) USB 2.0 drive - confirm this is the case, or tell us what it is (firewire, USB 3.0, etc.)
2) Windows OS - which version on school PC and your mates; or is it Apple, which one, etc.?
Check to insure your are not going through a USB 1.1 hub (for example if an external USB 2.0 drive is plugged into a monitor hub which is plugged into the PC, then your speed may only be USB 1.1 - too slow for Premiere)
And, make sure Windows policy is set to "better performance" instead of "quick removal" (the default) for your USB drive.
Good luck!
Jim
