I have a list of APIs in the TOC that has the folder names in Sentence case;
The TOC is somewhat like this:
-Product APIs
---xyz
------API documentation
---------foo
------------foo API1
------------foo API2
------Webservices API documentation
---------Foo
------------FooAPI1
------------FooAPI2
------------FooAPI2
The path to an API in Foo in the auto-generated files, such as in whdata, should be: /product_apis/xyz/webservices/Foo.
However, the path in the the auto-generated files changes to /product_apis/xyz/webservices/foo/
(note 'Foo' changes to 'foo')
Since Linux is case-sensitive, these API links do not work in Linux.
I have replaced all such instances by using a search and replace tool.
But this is only temporary.
How do I make sure the files maintain the correct case of the filepath or foldernames
Thanks and regards,
PT
Hi there
In RoboHelp when you examine your single source layout recipe there is an option for forcing all lower case when you generate the layout. Unfortunately my crystal ball is broken and my psychic skills are below par, so I cannot tell what version of RoboHelp you are using. If I knew that, I could tell you exactly where to find the option to see if it's been enabled or not.
Another thing that's a tad confusing is to ask if you are simply referring to what is shown in the TOC or topics or if you are just asking about file names.
Cheers... Rick
I forgot to mention that.
The RoboHelp version is 7.01
Panchamee
>>>> I am not worried about the TOC or the topics names.
The worry is how the filepath is generated and the case change; I get to see these filepaths in the files present inside whdata, whgdata and whxdata.
Hope I have answered your question
Hello again
In RoboHelp 7 if you examine the properties of your Single Source Layout recipe, look near the top of the first page of the dialog. There is where you see the option for lower case file names.
Actually, this option is intended to PREVENT things from going haywire when you publish. When it's enabled, the process of generating WebHelp ensures all file names are lower case. But it also ensures all links are amended to lower case so it will prevent broken links from occurring.
I'm confused as to your mention of what's inside the whdata, whgdata and whxdata files. These are auto generated by RoboHelp and there should never be a need to muck about with any of them. If you are, perhaps that's part of the issue?
Cheers... Rick
Okay, got it.
Thanks Rick!!
I could figure out why the links are breaking by knowing that the filapaths are being generated in all lowercase; I got to know about this by examining the auto-generated files. That's about it.
Thanks again
On Wed, 28 Sep 2011 22:02:50 +0530 wrote
Re: Webhelp forcefully generating files with lowercase filepath
created by Captiv8r in WebHelp - View the full discussion
Hello again In RoboHelp 7 if you examine the properties of your Single Source Layout recipe, look near the top of the first page of the dialog. There is where you see the option for lower case file names. http://forums.adobe.com/servlet/JiveServlet/downloadImage/2-3942922-84647/318-346/tmp1.PNG Actually, this option is intended to PREVENT things from going haywire when you publish. When it's enabled, the process of generating WebHelp ensures all file names are lower case. But it also ensures all links are amended to lower case so it will prevent broken links from occurring. I'm confused as to your mention of what's inside the whdata, whgdata and whxdata files. These are auto generated by RoboHelp and there should never be a need to muck about with any of them. If you are, perhaps that's part of the issue? Cheers... Rick http://www.robowizard.com/pc.gif Helpful and Handy LinksRoboHelp Wish Form/Bug Reporting FormBegin learning RoboHelp HTML 7, 8 or 9 within
the day!Adobe Certified RoboHelp HTML TrainingSorcerStone BlogRoboHelp eBooks
Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page:
To unsubscribe from this thread, please visit the message page at . In the Actions box on the right, click the Stop Email Notifications link.
Start a new discussion in WebHelp by email or at Adobe Forums
For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
