Heading 1 after index in printed output in ROBOHELP 8
Guest
Sep 28, 2011 Sep 28, 2011
In ROBOHELP 8 after the printed output has completed (standard order , title, TOC, chapters, glossery, index) there appears a blank line of heading 1 after the index.
This is not a problem with the standard template but if a style is used where headers are numbered and highlighted with different coloiurs the line loooks odd. The number also gets included in the TOC as a blank entry.
Is there any way to stop this heading line being created?
Regards
Dave White
601
Community Expert , Sep 30, 2011 Sep 30, 2011
If you do find an answer, please post a link back here.
@petergrainge
Sep 29, 2011 Sep 29, 2011
This can happen if you have background shading in the style and it is the full width of the page, you get the background behind the heading text and on the line above the page break. If that is the problem, it is a Word issue and you will get it in documents created in Word using the same styles.
I got around it by leaving the style as I wanted in the online help but reducing the shading in the Word template to being just behind the text.
If that is not it, then please add a screenshot.
@petergrainge
Guest
Thank you for the quick answer.
After investigating your reply (in Word forums) it certainly seams like it is related to a  WORD and not ROBOHELP problem.
Sadly I cannot fix it in the way you suggest as the format for WORD documents is closely defined by my customer.
I will continue to search for the solution on WORD forums.
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
