1. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
JEShort01 Sep 29, 2011 8:39 AM (in response to rowby)Windows 7 Home Premium only supports 16GB of RAM; is that possibly what is going on here?
Jim
2. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 8:41 AM (in response to JEShort01)Hi
I should have mentioned, I have Windows 7 Professional.
Rowby
3. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
Harm Millaard Sep 29, 2011 8:50 AM (in response to rowby)Rowby,
In the BIOS, disable XMP profiles.
4. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 9:16 AM (in response to Harm Millaard)HI Harm,
I went into the ASUS bios and changed the AI Overclock Tuner to Manual. I was given 4 choices
Manual
Auto
D.O.C.P
X.M.P.
And saved the BIOS configuration settings. (Went in again and double checked it and it remains at Manual.) BTW, Bios says System Memory Usable Size 16376MB after I went in and double checked the second time.
However Windows 7 Professional in Control Panel System still says "Installed Memory 16.0 GB"
Rowby
5. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
JSS1138 Sep 29, 2011 9:21 AM (in response to rowby)The CPU-Z report show dual channel memory, but the board supports triple channel memory. Curious.
I wonder if you might have a couple of bad modules on your hands.
6. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 9:28 AM (in response to JSS1138)Hmmmm. The Corsair Vengeance Box says it's DDR3 memory.... (Newly installed right out of the Box -- from Amazon....)
My motherboard bios is Version 0703 Build date 02/24/10
MVL9123 FW Version 01001014
Rowby
7. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
Harm Millaard Sep 29, 2011 9:29 AM (in response to rowby)You should not use the AI Overclock utility, but only the Advanced settings tab. First get the memory to work correctly. If needed, I can make pictures of my BIOS settings. I had the same problem initially, but it was easily resolved by turning off XMP profiles.
8. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 10:21 AM (in response to Harm Millaard)Hi Harm,
In the advanced tab I see under CPU CONFIGURATION
CPU Rating Setting
C1E support
Hardware Prefetcher
Adjacent Cahce LIne PRefetch
INtel Virtulization Tech
CPU TM Funciton
Execute Disable Bit
Intel HT Technology
Active Processor Cores
A20M
Intel Speed STep Tech
Intel Turbo Mode Tecdh
Intel C State Tech
WHich one would I modify, if any.
cpu advanced.jpg 60.9 K
9. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
ECBowen Sep 29, 2011 10:30 AM (in response to rowby)Unfortunately you have run into the ram compatibility/timing issue with the sticks and memory controller on the cpu. There are several bios settings you have to change/setup to configure the ram. If you dont want to deal with those then you can try moving the pairs around and see if any pair will start playing better with a different partner. Harm's idea was one of the ways to try and deal with it as well. I can post the bios settings if you want to change them.
Eric
ADK
10. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 10:55 AM (in response to ECBowen)HI
Let's try changing the bios settings first. The memory came as a pak so hopefully they will play together without moving them around.
Please post the bios settings that might fix this.
Rowby
11. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
ECBowen Sep 29, 2011 11:23 AM (in response to rowby)Well before you do the settings, you need to get the bios updated for the memory compatibility.
http://support.asus.com/download.aspx?SLanguage=en&p=1&m=P6X58D+Premium&hashedid=wurRaDZ8l o4Ckukj
Version 1501
Make sure you go down to 1 stick when you run this update. Also load optimized defaults after it updates on the next bootup then save and exit so the board re-detects all of the ram timings. Power down the system and then install the rest of the ram. The bios settings come after that once we see what the ram detection is.
Eric
ADK
12. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 11:26 AM (in response to ECBowen)Thanks. WIll do the bios update!
Rowby -
13. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 11:39 AM (in response to ECBowen)Hi
It won't boot up with one stick. Only with two sticks. So I am booting up with 2 sticks.
...Rowby
14. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 11:47 AM (in response to rowby)I downloaded the latest bio file. but the Asus FAQ on how to do the update -- is not working (bunch of asus server errors!)
So am not sure how to use this file to update the motherboard bios.
Will google it, but if you have some quickie instructions please post.
Rowby -
15. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
ECBowen Sep 29, 2011 11:49 AM (in response to rowby)Ok you need to try each stick 1 at a time in slot 0 on the board and see if each one will post the system correctly. See if any 1 stick besides that one will not allow the system to post. Put any of those to the side. Once you narrow that down then you can run the update.
Eric
ADK
16. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 12:08 PM (in response to ECBowen) -
17. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
ECBowen Sep 29, 2011 12:18 PM (in response to rowby)I forgot they label it A1 and 2. A1 is the slot I was talking about or the closest blue to the CPU.
Eric
ADK
18. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 12:51 PM (in response to ECBowen)Good. By me putting it in the blue slot (nearest the CPU) the machine booted up with one stick.
Do you have a link to the Asus BIOS installation utility?
I'm looking for it.
Rowby
19. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
ECBowen Sep 29, 2011 12:55 PM (in response to rowby)Go into the bios and over to tools. Select the EZ Flash and launch the utility. Then go to the location where the bios file is and update. Very easy to do on Asus boards.
Eric
ADK
20. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 1:34 PM (in response to ECBowen)SUCCESS!
Windows now shows 24GB of memory!
Just doing the bios update fixed it all.
Thanks Erid and Harm! This forum is an incredible resource.
I'm sure I need to do some things to further refine the bios settings, but this is certainly a relief.
I will leave this discussion open in case there are any updates.
In the meantime I am going to post another question regarding the memory in my Areca board... Stay tuned.
Rowby
21. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
ECBowen Sep 29, 2011 1:46 PM (in response to rowby)The bios settings then are just for performance optimization. I would download this tonight and make a disc from the ISO. Restart the system before you go to bed and let this run all night. Make sure there are no errors when you wake up in the morning. If you get any errors, then you will have to play with the bios settings after all.
http://www.memtest.org/download/4.20/memtest86+-4.20.iso.gz
Eric
ADK
22. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 2:04 PM (in response to ECBowen)Will do!
And will report back here!
Rowby
23. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 2:13 PM (in response to ECBowen)WHen you say make a "disk iso" I assume you want me to make an iso from the gz file -- and burn it to a cd and then boot from the CD?
Rowby
24. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
ECBowen Sep 29, 2011 2:22 PM (in response to rowby)There is already an ISO file in the zip file. Just unzip and then you can burn the ISO to Disc.
Eric
ADK
25. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 5:51 PM (in response to rowby)Hi
Extracted the gz onto my drive and then clicked on the img and created an CD (see attached photo)
Set the bios to boot from the CD first priority (see attached photos)
However, Windows 7 refuses to boot from the cd -- keeps booting to Windows 7 rather than botting from the cd.
When I tried, in bios, completely disabling the hard drive, and only enabling the cd drive, during bootup windows complains about there not being a bootabe drive -- and I have to alt-control-delete to reboot.
So it appears that there is nothing to "boot" from, on the cd, which is why Windows 7 can't boot from it.
Rowby
26. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 6:18 PM (in response to rowby)Hmmmm
I put the cd in my laptop, set the CD to be the first drive and -- the computer booted from the cd.
So I'm trying to figure out why my editing computer won't boot from the cd.
27. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Sep 29, 2011 6:28 PM (in response to rowby)Interesting. I disconnected the CD cables (power and the the other cable) and rebooted.
Bios, under Boot Device Priority is still showing as the 2nd boot device "ATAPI CD-ROM".
Now I'm wondering, my burner is a DVD not a CD. So is it possible that the "ATAPI CD-ROM" is some sort of a generic identification in bios, and in fact BIOS is not seeing my DVD burner at at all?
However windows 7certainly saw the "CD drive" when it let me burn the iso to the cd... Baffled!
Rowby
28. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
Crist OC/PC Sep 29, 2011 10:33 PM (in response to rowby)Your motherboard is not recognize all your ram, Go to bios and set all ram time manualy, there are probably 2 slot wich hav´t been set recognized.
That is the only problem you have...
Have a nice day.
B.R. Cristobal Salas.
29. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
ECBowen Sep 30, 2011 8:33 AM (in response to rowby)That is a generic listing for boot device. You want to look for a listing that includes the model number for your DVD drive. That is the way most boards list optical drives now days.
Eric
ADK
30. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
Rowby Goren Sep 30, 2011 9:09 AM (in response to ECBowen)Hi Eric,
Updating my dvd drive's firmware and then later today I'll follow your instructions re id'ing the dvd drive.
Thankx
Rowby
31. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
Rowby Goren Sep 30, 2011 10:20 AM (in response to ECBowen)Okay! Updated my firmware and the board finally correctly ID'd the dvd burner. And I was able to boot from the CD.
Now I'm running Memtest86. v4.20.
Running 17 minutes so far and no errors.
Running Test #4 right now.
I'll let it run all day, I guess!
I see a (c)configuration item on the bottom of the screen. I am ignoring that and am running the test in its default settings.
Hee hee!
Rowby
32. Re: Windows 7 System only recognizing 16GB out of 24GB newly installed
rowby Oct 1, 2011 11:21 AM (in response to Rowby Goren)Ran 5 passes of memtest and no errors.
I guess the next step will be some memory configurations?
Rowby
