The topic will only contain 1 image. I can center-align it horizontally. Can I center it it vertically?
Hi there
The only reliable way I've ever found to do it is by using CSS and specifying the image as a centered background image.
Cheers... Rick
The image contains image maps with links to other topics. Will either css or watermark support that?
If so, how do I do either one?
Thanks.
Hi there
The link below will show you how to configure a watermark.
No, Image Maps are not supported with watermark images.
Cheers... Rick
You are probably looking for a watermark. See this excellent blog post by Kevin Siegel: http://iconlogic.blogs.com/weblog/2011/07/adobe-robohelp-watermarks-made-easy.html
For entering the image directly, you have to play around with css. See http://www.jakpsatweb.cz/css/css-vertical-center-solution.html for an example.
Greet,
Willam
