1. Re: Is this the right 2GB memory for my Areca ARC-1880ix
ECBowen Sep 29, 2011 2:10 PM (in response to rowby)"
One 240-pin DIMM socket for DDR2-800 ECC registered
SDRAM module using x8 or x16 chip organization, upgrade
from 1GB (default) to 4GB (ARC-1880ix-12/16/24)
Based on that you need DDR2 Reg ram and not unbuffered. The Kingston stick part number looks like an unbuffered stick.
Eric
ADK
2. Re: Is this the right 2GB memory for my Areca ARC-1880ix
rowby Sep 29, 2011 2:11 PM (in response to ECBowen)Thanks!
Back to amazon. Hee hee!
I'll find one there are post it here for review.
Rowby
4. Re: Is this the right 2GB memory for my Areca ARC-1880ix
ECBowen Sep 29, 2011 2:23 PM (in response to rowby)No that is an FB Dimm which is different from an RDimm. You need a RDimm.
Eric
ADK
5. Re: Is this the right 2GB memory for my Areca ARC-1880ix
rowby Sep 29, 2011 2:31 PM (in response to ECBowen)Here is the online store where I bought the board (Tekram) -- great areca support, btw.
Should I just buy the 2 GB version here.
http://tekram.com/store/index.php?cPath=28
Rowby
6. Re: Is this the right 2GB memory for my Areca ARC-1880ix
Harm Millaard Sep 29, 2011 2:37 PM (in response to rowby)Rowby,
This is likely the module you are looking for:
Kingston ValueRAM KVR800D2E5/2G
7. Re: Is this the right 2GB memory for my Areca ARC-1880ix
rowby Sep 29, 2011 4:09 PM (in response to Harm Millaard)Thanks Just ordered it at amazon.
8. Re: Is this the right 2GB memory for my Areca ARC-1880ix
rowby Oct 4, 2011 12:34 PM (in response to rowby)As it turned out the memory ordered from amazon would not work. (No problem, a computer geek friend wanted it so it is now having a happy home in his computer).
I'll probably buy the memory from Tekram.
Rowby
9. Re: Is this the right 2GB memory for my Areca ARC-1880ix
JEShort01 Oct 4, 2011 6:25 PM (in response to rowby)Rowby,
Do NOT order the 2GB stick from the link you provide above for a ARC-1880 series controller card. The only one that they show on that link that would be compatible is the $249 4GB 800MHz stick. If you click on the "details" button by each you can view what cards each RAM stick is compatible with.
If I were you, I would just stick with the 1GB RAM. And, if that is not fast enough for your needs, buying more hard drives would probably help your system's performance more than the cache upgrade.
Jim
10. Re: Is this the right 2GB memory for my Areca ARC-1880ix
rowby Oct 5, 2011 6:46 AM (in response to JEShort01)HI
Thanks for that. I'll hold off the areca memory for now !
Rowby
