I have an external hyperlink in the form of http://www.server.gov in the last slide of the presentation. The link is not selectable in the published presentation. I'm using office 2010 32 bit, windows 7, presenter 7.0.7 build 7746. The published presentation is on the web server and I'm accessing the presentation with IE. I've tried deleting the link and reinserting it. Any suggestions on what to try next?
I tried on same configuration for both PPT nad PPTX but I am not able to repro the issue.
Please verify; if we play the Presenter published file on local system then hyperlinks are accessible?
If answer for above is yes then I can suggest you to check "Enable window popup" is unchecked.
Shubhi
Is there a drop shadow on the link? That will cause Presenter to disregard the link when publishing it!
A fun little issue that took a while to find the first time.
Yes, if hyperlink text have text Effects/wordstyle then hyperlink won't work; this is known issue in presenter 7.0.7 and will be fixed in new release.
