Hi all
just installed flash builder 4.5 , then installed the flash builder 4.5.1 update patch
I've noticed the code generation features are not working
meaning for example if I write "fori" in a function then hit ctrl+space
it opens up an empty window with no suggerstions
same goes when I tried generating variables, functions, classes, getters, setters ect...
any idea as to why does it happen or what can I do about it?
cheers
Are you using an old workspace? If so, can you try with a new workspace.
Also, are features such as syntax highlight, mark occurrences,.. working?
Sameer hello and thank you for your response
the workspace is completely new
syntax highlight & mark occurrences works fine
any ideas?
Can you try a few things please -
1. Post the content of your workspace log here. Log can be found in <workspace location>/.metadata/.log
2. Post the steps you performed (starting from creating a new project) along with the .as and .mxml files. If you can't post your files here, please mail them to me at sameer[at]adobe[dot]com
3. Create a new workspace using File > Switch Workspace > Other. Create a new Flex project in the workspace and try these features.
Let me know your findings.
