I was trying to allow a user to select a range of dates so
that they can search the database. It works great with one problem
that might be considered as a bug. I wanted to see if anybody knows
how to solve this problem before I go and report it.
Here's the problem:
Using the code attached, once the first select box is
populated without scrolling through the months and then the second
datefield is populated a problem arises. So once you try to select
another date in the first datefield box in a month that is at least
4 to 5 months before, some dates don't display. I thought it was a
white on white error but I couldn't change the calender's font
color. So I figured that if I didn't display today's date on the
first select field that it would take care of the error. This
worked when I used "Datename1.showToday = false;" in the start of
the RangeStart function. The thing is, I would like to keep today's
date selected but haven't found another way around the issue. Does
anybody know what I could to do eliminate this problem.
Jeff
