7 Replies Latest reply on Aug 15, 2012 3:33 AM by nikos101
    Flex app calling CF cfc to download file gets "Channel disconnected" fault
    Godico77 Level 1
      I am a newbie with ColdFusion and Flex. I am trying to implement file download/streaming functionality in my Flex 4.5 application and I am running ColdFusion 9 as my back end. More specifically, I have a component in my Flex app that displays a list of files - some of these files can be available for opening (or "previewing") via the client. I want the client to be able to click a button and download the file from the ColdFusion server, after the appropriate security checks are performed (also in ColdFusion). Right now I am just trying to get the basic download functionality to work with a very simple cfc. Here is the cfc code:
      <cfcomponent displayname="Preview Document"
           <cffunction name="streamFile" access="remote" returntype="any">
                <cfargument name="filename" displayName="Filename" type="string" required="true" />
                <cfheader name="Content-Disposition" value="attachment;filename=#filename#" >
                <cfcontent type="application/unknown" file="c:\myserverpath\#filename#">
      When I try this via a cfm, it works fine (I get a File Download window where I can choose to either open or save the file). But when I try to use this in my Flex app, I get an error.
      In my Flex app, I have a RemoteObject to access my cfc and a CallResponder:
      <s:RemoteObject id="PreviewDocument"
        <s:CallResponder id="PreviewDocumentResult"
          fault="Alert.show('CallResponder PreviewDocumentResult: ' +
          event.fault.faultString + '\n' + event.fault.faultDetail)"
      Then I created a button whose click even executes the following line:
      PreviewDocumentResult.token = PreviewDocument.streamFile(
      When I run my app, I get the following fault:
      faultCode = "Client.Error.DeliveryInDoubt"
      faultString = "Channel disconnected"
      faultDetail = "Channel disconnected before an acknowledgement was received"
      I have tried many different approaches and searched online for help with this fault, but I could not find any helpful clue to where I can start investigating this.
      Can anyone help with why I am getting this fault?
      Thanks in advance.
