Long time ago when I was trying to use Robohelp in an emergency without proper knowledge, I eradicated the Glossary button from my project, and now I don't get a Glossary button no matter what skin I select.
I cannot retrace my steps, as it was too long ago and I can't duplicate them.
I did not use the usual method of Properties > Navigation > Toolbar Buttons.
Is there any hope to reverse this mistake or reset default Robohelp?
I have not created any glossary items yet, figuring it's a waste of time if I dont get a button 😉
So you're saying, create some glossary items and I may get the button to show. I will do so. May need some clarification on what it means to select an SSL recipe...
Is there a glossary in the RH project? If so, you should be able to select it in the SSL recipe you used to create the help.
Hi there
What is your output type? What is your RoboFlavor?
The Glossary button may or may not be available for a few different reasons. It would appear Jeff mentioned one of them, but there are others if he would pause and think about it.
Until we know more we really can't say exactly why you don't see a Glossary Button. Certainly defining the Glossary is a first step.
Cheers... Rick
Robohelp 9. WebHelp primary layout. Currenty adding a few glossary items...
Ah, creating some glossary items resulted in the Glossary button appearing after build. Problem solved. Thanks a million of the help.
So right, Rick!
Working in an absence of info, I stick with the obvious & vague ;>)
