1
Auto Flow Multi Page PDF
Oct 04, 2011 Oct 04, 2011
I'm wondering if anyone knows of a way to automatically flow a multiple-page PDF into InDesign CS5. I have a 350 page PDF that I need to import, each page of the PDF as a new page in the document. Something that works like the shift + click with a loaded cursor for word documents? Or a script that allows me to place PDFs that way?
30.2K
Community Expert , Oct 04, 2011 Oct 04, 2011
open your scripts panel, either in apple scripts or java: find placeMultiPagePdf and double click: follow and select from dialogue
G
there is a script for this... cant be done otherwise
Why not just combine that PDF with whatever you’ll be adding to it in InDesign in Acrobat?
Bob
Jul 27, 2021 Jul 27, 2021
Nice share.
Thanks Grant H
G
Jul 24, 2015 Jul 24, 2015
u r right
hmmn: just tried it... gives more options and works in ID 5.5...
There's an earlier version too, for earlier versions of ID.
Open your indesign window manu > and find utilities option and click on script panal you will see a script sub-window on your screen click on javascript and find placeMultiPagePdf option and click double and choose your document and enjoy your self
Dec 09, 2015 Dec 09, 2015
I have an InDesign Layout for which I need to print two up per sheet...full bleeds so I need to flow the multipage pdf to respect the columns.  I will then trim them out with the full bleed.  The script causes it to align with the upper left corner rather than flowing into the respective columns as a text file would.  Please help!
I think we're going to need screen shots....
paper is 12 X 18
Each side will be trimmed to 8.5 X 11 and is a total of 1403/702 sheets
Once the pdf is flowed throughout, I will add the background to the Master pages.
Cheri
Peter:
The only other way I can think of is to flow all pages into an 8.5 X 11 InDesign document, then recreate a booklet pdf, then re flow into an 11 X 17 InDesign doc, then change the page size to 12 X 18 and add my background to master pages...I just won't have the appropriate bleed in the center, but I can probably fudge it when I cut.  If you know of a better way to accommodate the bleeds...I am so ready to listen.
Thanks for your prompt help.
Cheri
Is this a data merge project? It would be pretty easy to set up that way....
No...this came from the client as a pdf.
so you blanked out information that is different between the two sides on your screen shot?
Do they have to be in a particular order?
Each page is unique, but I think I can mix up the order of the personalized letters.
Peter:
I think I solved my own problem with this for printing two out and with the full bleed.  Once I flowed the pdf as 8.5 X 11, then changed my doc size to 9 X 12, dropped in my background on the master page, my printer allows me to choose 2 up on 12 X 18 AND choose the order as down then across etc.  THANK YOU for all your help.
Cheri
Yes.  Those spots contain personal information, so simply put black boxes over them so acct #s weren’t out for the world to see.  Obviously the black boxes won’t be there.
Cheri
Glad you solved it. As far as personal info, though, you need to delete yours when you reply by email. I'll do it for you on the last post.
Thank you.
Cheri
Apr 14, 2018 Apr 14, 2018
Problem i am having is it does not center it, do i have to write a script, not sure how.
Hi Timothy,
try the MultPageImporter script originally written by Scott Zanelli, now curated by Mike Edel:
https://github.com/mike-edel/ID-MultiPageImporter/releases
Uwe Laubender
( ACP )
Well, a note to myself:
First read the date of a post, then answer…
Uwe Laubender
( ACP )
