I am trying to get a button to show an object that has a sound associated with it. This works fine, except that when clicked, everything else on the slide disappears. I tried shortening the "pause after" time to .5, and this worked if the button is clicked once. But when I click the button a seond time--to replay the sound--I have the same problem.
Any ideas?
Thank you!
Can you upload a screenshot of your timeline for this slide?
Do the other objects on your slide have Fade In Fade Out transitions?
Wow--that was fast!
Pointing me to the transitions helped me figure it out--The issue was in the timing, and all I had to do is set it to display for the rest of the slide.
Thank you!!!
