Changing coding from UTF-8 to ANSI
Guest
Oct 05, 2011 Oct 05, 2011
Hi all,
in one project an older RoboHep version was in use until now that produced ANSI-coded HTML files (Latin-1 I think). The webhelp output was published on a server and everything worked fine. Now after upgrade to RoboHelp 9 the HTML files are coded with UTF-8 and the server application cannot display this correctly (particularly German umlauts are scrambled). Is there any way to change the coding used by RoboHelp? Are you aware of a script or tool that could be used to manually convert the Webhelp output back to ANSI (i.e. all HTML files in the subfolders of the output folder)?
Robert
1.7K
You can use LibIconv for that: http://www.gnu.org/software/libiconv/ Convert from UTF-8 to iso-8859-1. It's a command line tool, so you will need some kind of script to mass convert all your topics.
But can't you reconfigure the server application to work correctly with UTF-8? Otherwise you will need to convert all your output files every time you create an output.
Greet,
Willam
The webhelp generation dialog allows you to change the encoding.
@petergrainge
Guest
Thanks for the ideas!
Robert
@Peter: Nah, that's way too easy. Can't believe I missed that
Guest
Yep that did the trick. It's a new feature and I did not notice it yet.
RoboHelp Documentation
Download Adobe RoboHelp
