I have a set of custom components (usually) extending Spark components. But when adding our custom component onto design view, how can I define defult values (in AS3).
For example, s:Button has default label = 'Button' when added to application, or mx:DataGrid has 3 columns predefined, but when using custom components there are no predefined values like this.
I can put this values in constructor, but they are not visible in design time, only runtime.
Any ideas? Thanks
Esmin
yes, I am. By the way I've found the solution. Someone might find this usefull.
In design.xml having
<component name="ExtendedTextInput" namespace="mynamespace" category="beta" displayName="ExtendedTextInput"/>
use this
<component name="ExtendedTextInput" namespace="mynamespace" category="beta" displayName="ExtendedTextInput">
<defaultAttribute name="text" value="ExtendedTextInput"/>
</component>
so when adding this component to design view, it will have text setted to value ('ExtendedTex
...Copy link to clipboard
Are you calling super in your constructor?
use this
</component>
so when adding this component to design view, it will have text setted to value ('ExtendedTextInput' in this case).
