4 Replies Latest reply on Oct 6, 2011 12:58 PM by Gloria Diaz
    Digital signatures export as ns dataNode in my XML file
    Gloria Diaz Newcomer
      I created a simple form and need to copile responses as they are returned.  I have been able to set it up and it works beautifully except for the electronic signature fields.  There are two signature fields.  There are two signature fields.  When I export the files as
      XML and open it up in Excel, there are three records for each file.  The signature field is labeled "ns1:  dataNode"; for two of the records, the column reads "dataGroup"; the third is empty.  I am currently using LiveCycle Designer ES2 and Acrobat X Pro.  What I would like in my Excel file is an indicator of whether or not there is an electronic signature present in each of the two signature fields.  Can someone help?
      Thank you,
      Gloria Diaz
