1 2 Previous Next 43 Replies Latest reply on May 22, 2012 5:24 PM by chris.campbell
    Flash Player 11 constantly crashing on every Website with Flashcontent...
    astefanosstefas Level 1
      I am having problems with the latest Update of Adobe Flash Player to release 11. I am on a Mac(10.6.8) running the 64bit kernel. At the moment I installed Flash Player 11, every Website with Flashcontent is crashing. This also happens in Chrome, not only Safari or Firefox. I did everything Adobe provides as possible solutions. Do an uninstall with the uninstaller, then install fresh. I had a look in both of the Internet Plugins folder to make sure everything got removed correctly. But the new install won't work.
      What works is uninstalling Flash Player 11 and installing Flash Player 10.3 again. Everything works like a charm then. Well... except in Chrome of course.
      Just as a last bit of information: I never had any beta or alpha versions of the player installed.
      Can anyone please help me? Does anyone else encounter this problem?
      Regards
      Alex
        • 1. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
          aylarov
          I have the same problem with Mac OS X (10.7.1) , it constantly crashes on every website with Flash content in any browser I tried. Adobe, any comments??
          P.S. Downgrade to 10.3 helps.
          • 3. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
            libflashplayer.so Adobe Employee
            can you post your system overview information?  also state your Graphics/Display information.  ii'm wondering if it is harware specific.
            • 4. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
              thanks for the replies. The following are my hardware specs. One can not be sure that it might be a damaged hardware but it is very unlikely as i got my motherboard and graphicscard exchanged only 3 month ago. I also can play gpu accelerated games...
              Alex
              Bildschirmfoto-2011-10-08-um-12.30.01.pngBildschirmfoto-2011-10-08-um-12.30.19.pngBildschirmfoto-2011-10-08-um-12.30.29.png
              • 5. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                I also did a test in my Windows XP Virtual Machine(installed the Flash Player 11) running on the very same MacBook Pro. No problems there so I think my hardware is ok.
                - It is not 64 bit obviously, if that makes any difference -
                Regards
                Alex
                • 6. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                  zx3cv1zx30vzx23c01v3zxc21 Level 1
                  Hi guys,
                  this has been dealt with specifically on several posts on teh web, including the officil spec list on the features page of the flash 11 update (known issues).
                  Flash player is not working with some macs due to driver issues, hence it will work with windows on the mac.
                  Adobe has flagged it to Apple and request they prioritise a fix for it hwoever Apple has said it is a low priority and wont be addressed - they ar once again doing everything they can NOT to help.
                  • 7. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                    well the kind of macbook pro i have is one of the most standardized hardwares out there. There have to be a lot of others experiencing the same problem and somehow I can not imagine that Adobe is publishing a player which is not running on any macbook pro out there. It is not an exotic setup at all.
                    Can you please provide a link to these known issues? I had a look but did not find them.
                    Regards
                    Alex
                    • 8. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                      I found that other forumpost. Seems to be exactly the same problem with the same hardware specs. http://forums.adobe.com/message/3960079#3960079
                      Regards
                      Alex
                      • 9. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                        Here is the one from Adobe
                        http://kb2.adobe.com/cps/919/cpsid_91932.html
                        Known Issues
                        Stage 3D
                        • Mac: On Mac OS X, hardware accelerated rendering is not supported on Intel GMA, ATI Radeon x1600, and ATI Radeon 2400 cards.
                        • Stage3D uses the integrated GPU on MacBook Pro’s with Intel i7 or i5 processors (2943979).
                        • Hardware accelerated rendering is not supported on VIA chipsets.
                        • 10. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                          thanks for the "Known Issues". I thought you had another list in mind, because this is what I found aswell. Unfortunately this discribes something different. I have a NVidia GPU and I would not care that much if hardware acceleration was buggy. But all Flashcontent is crashing. Even the simplest Frame by Frame Animation and also any content targeting Player 10 that is not relying on any GPU at all.
                          So I think the crashes is another issue as the list describes possible situations where you have not full access to hardware acceleartion which should not crash the Player.
                          Alex
                          • 11. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                            I tried also the Flash player 11 and Flash Player Debugger 11 Standalone Players on my mac and they both also crash...
                            Regards
                            Alex
                            • 12. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                              we've tested several of the same machine that you have and are having difficulty reproducing the crashes you are experiencing.
                              when do the Standalone players crash?  at launch? or when content is loaded?
                              would you mind to forward me your crash logs from Firefox?  if you type about:crashes in the address bar it will list your crashes.  please send me the ones prepended with "bp-"  these are the ones that were submitted to Mozilla.
                              • 13. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                should I send you the link? Or should I just copy & paste all of it?
                                • 15. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                  the standalone players are crashing right after compiling and testing an swf. targeting player 10 but using the standalone 11...
                                  • 16. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                    thank alex.  i'll see if dev can see anything obvious in the file.
                                    • 17. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                      Sorry, that is just the adobe one.
                                      I have read lots of these in my travels over the past couple of days - ALL of which are relating to MAC and the drivers for the GPU cards.
                                      I can not see any reason at all why the flash player would crash on your system between the two players other than GPU issues. Especially since it is the primary variation is known
                                      to be the cause.
                                      I would suggest installing a virtual machine - windows etc, as this has been shown to work, if it is indeed successful then you know you need to speak to Apple about keeping up to date with their drivers.
                                      • 18. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                        Yeah, you are probably right. I just thought that there was a statement i have overread saying, crashes on blablabla... Maybe I was to optimistic about my mbp/specs not being explicitly in the list..
                                        Thanks a lot for following these posts...
                                        • 19. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                          alex_  from the Mozilla crash-stat link you provided, we think the issue is in the area of font loading.  can you let use know what system language you have on and a list of fonts you have on your system?  our dev is looking at it more closely, but it would be great if we could reproduce the issue.
                                          • 20. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                            my system language is german.
                                            This is the content of my systems font folder. The ones with the ?? ae some asiatic fonts. They should be on every mac i think:
                                            Academy Engraved LET Fonts
                                            ACaslonPro-Bold.otf
                                            ACaslonPro-BoldItalic.otf
                                            ACaslonPro-Italic.otf
                                            ACaslonPro-Regular.otf
                                            ACaslonPro-Semibold.otf
                                            ACaslonPro-SemiboldItalic.otf
                                            AGaramondPro-Bold.otf
                                            AGaramondPro-BoldItalic.otf
                                            AGaramondPro-Italic.otf
                                            AGaramondPro-Regular.otf
                                            AlBayan.ttf
                                            AlBayanBold.ttf
                                            AmericanTypewriter.ttc
                                            Andale Mono.ttf
                                            Apple Chancery.ttf
                                            Apple LiGothic Medium.ttf
                                            Apple LiSung Light.ttf
                                            AppleCasual.dfont
                                            AppleMyungjo.ttf
                                            Arial Black.ttf
                                            Arial Bold Italic.ttf
                                            Arial Bold.ttf
                                            Arial Italic.ttf
                                            Arial Narrow Bold Italic.ttf
                                            Arial Narrow Bold.ttf
                                            Arial Narrow Italic.ttf
                                            Arial Narrow.ttf
                                            Arial Rounded Bold.ttf
                                            Arial Unicode.ttf
                                            Arial.ttf
                                            ArialHB.ttf
                                            ArialHBBold.ttf
                                            ArnoPro-Bold.otf
                                            ArnoPro-BoldCaption.otf
                                            ArnoPro-BoldDisplay.otf
                                            ArnoPro-BoldItalic.otf
                                            ArnoPro-BoldItalicCaption.otf
                                            ArnoPro-BoldItalicDisplay.otf
                                            ArnoPro-BoldItalicSmText.otf
                                            ArnoPro-BoldItalicSubhead.otf
                                            ArnoPro-BoldSmText.otf
                                            ArnoPro-BoldSubhead.otf
                                            ArnoPro-Caption.otf
                                            ArnoPro-Display.otf
                                            ArnoPro-Italic.otf
                                            ArnoPro-ItalicCaption.otf
                                            ArnoPro-ItalicDisplay.otf
                                            ArnoPro-ItalicSmText.otf
                                            ArnoPro-ItalicSubhead.otf
                                            ArnoPro-LightDisplay.otf
                                            ArnoPro-LightItalicDisplay.otf
                                            ArnoPro-Regular.otf
                                            ArnoPro-Smbd.otf
                                            ArnoPro-SmbdCaption.otf
                                            ArnoPro-SmbdDisplay.otf
                                            ArnoPro-SmbdItalic.otf
                                            ArnoPro-SmbdItalicCaption.otf
                                            ArnoPro-SmbdItalicDisplay.otf
                                            ArnoPro-SmbdItalicSmText.otf
                                            ArnoPro-SmbdItalicSubhead.otf
                                            ArnoPro-SmbdSmText.otf
                                            ArnoPro-SmbdSubhead.otf
                                            ArnoPro-SmText.otf
                                            ArnoPro-Subhead.otf
                                            Ayuthaya.ttf
                                            Baghdad.ttf
                                            Bank Gothic
                                            Baskerville.ttc
                                            BellGothicStd-Black.otf
                                            BellGothicStd-Bold.otf
                                            BiauKai.ttf
                                            BickhamScriptPro-Bold.otf
                                            BickhamScriptPro-Regular.otf
                                            BickhamScriptPro-Semibold.otf
                                            BigCaslon.ttf
                                            BirchStd.otf
                                            Blackmoor LET Fonts
                                            BlackoakStd.otf
                                            BlairMdITC TT-Medium
                                            Bodoni Ornaments ITC TT
                                            Bodoni SvtyTwo ITC TT
                                            Bodoni SvtyTwo OS ITC TT
                                            Bodoni SvtyTwo SC ITC TT
                                            Bordeaux Roman Bold LET Fonts
                                            Bradley Hand ITC TT-Bold
                                            Brush Script.ttf
                                            BrushScriptStd.otf
                                            Capitals.dfont
                                            Chalkboard.ttc
                                            Chalkduster.ttf
                                            ChaparralPro-Bold.otf
                                            ChaparralPro-BoldIt.otf
                                            ChaparralPro-Italic.otf
                                            ChaparralPro-Regular.otf
                                            CharcoalCY.dfont
                                            CharlemagneStd-Bold.otf
                                            Cochin.ttc
                                            Comic Sans MS Bold.ttf
                                            Comic Sans MS.ttf
                                            CooperBlackStd-Italic.otf
                                            CooperBlackStd.otf
                                            Copperplate.ttc
                                            Corsiva.ttf
                                            CorsivaBold.ttf
                                            Courier New Bold Italic.ttf
                                            Courier New Bold.ttf
                                            Courier New Italic.ttf
                                            Courier New.ttf
                                            Cracked
                                            DecoTypeNaskh.ttf
                                            DevanagariMT.ttf
                                            DevanagariMTBold.ttf
                                            Didot.ttc
                                            EccentricStd.otf
                                            EuphemiaCASBold.ttf
                                            EuphemiaCASItalic.ttf
                                            EuphemiaCASRegular.ttf
                                            Futura.ttc
                                            GaramondPremrPro-It.otf
                                            GaramondPremrPro-Smbd.otf
                                            GaramondPremrPro-SmbdIt.otf
                                            GaramondPremrPro.otf
                                            GenevaCY.dfont
                                            Georgia Bold Italic.ttf
                                            Georgia Bold.ttf
                                            Georgia Italic.ttf
                                            Georgia.ttf
                                            GiddyupStd.otf
                                            GillSans.ttc
                                            GujaratiMT.ttf
                                            GujaratiMTBold.ttf
                                            Gungseouche.ttf
                                            Gurmukhi.ttf
                                            Handwriting - Dakota
                                            HeadlineA.ttf
                                            Hei.ttf
                                            HelveticaCY.dfont
                                            Herculanum.ttf
                                            Hiragino Sans GB W3.otf
                                            Hiragino Sans GB W6.otf
                                            HoboStd.otf
                                            Hoefler Text Ornaments.ttf
                                            Hoefler Text.ttc
                                            Impact.ttf
                                            InaiMathi.ttf
                                            Jazz LET Fonts
                                            Kai.ttf
                                            Kailasa.ttf
                                            Kokonor.ttf
                                            KozGoPro-Bold.otf
                                            KozGoPro-ExtraLight.otf
                                            KozGoPro-Heavy.otf
                                            KozGoPro-Light.otf
                                            KozGoPro-Medium.otf
                                            KozGoPro-Regular.otf
                                            KozMinPro-Bold.otf
                                            KozMinPro-ExtraLight.otf
                                            KozMinPro-Heavy.otf
                                            KozMinPro-Light.otf
                                            KozMinPro-Medium.otf
                                            KozMinPro-Regular.otf
                                            Krungthep.ttf
                                            KufiStandardGK.ttf
                                            LetterGothicStd-Bold.otf
                                            LetterGothicStd-BoldSlanted.otf
                                            LetterGothicStd-Slanted.otf
                                            LetterGothicStd.otf
                                            LithosPro-Black.otf
                                            LithosPro-Regular.otf
                                            MarkerFelt.ttc
                                            MesquiteStd.otf
                                            Microsoft Sans Serif.ttf
                                            MinionPro-Bold.otf
                                            MinionPro-BoldCn.otf
                                            MinionPro-BoldCnIt.otf
                                            MinionPro-BoldIt.otf
                                            MinionPro-It.otf
                                            MinionPro-Medium.otf
                                            MinionPro-MediumIt.otf
                                            MinionPro-Regular.otf
                                            MinionPro-Semibold.otf
                                            MinionPro-SemiboldIt.otf
                                            Mona Lisa Solid ITC TT
                                            MshtakanBold.ttf
                                            MshtakanBoldOblique.ttf
                                            MshtakanOblique.ttf
                                            MshtakanRegular.ttf
                                            MyriadPro-Bold.otf
                                            MyriadPro-BoldCond.otf
                                            MyriadPro-BoldCondIt.otf
                                            MyriadPro-BoldIt.otf
                                            MyriadPro-Cond.otf
                                            MyriadPro-CondIt.otf
                                            MyriadPro-It.otf
                                            MyriadPro-Regular.otf
                                            MyriadPro-Semibold.otf
                                            MyriadPro-SemiboldIt.otf
                                            Nadeem.ttf
                                            NewPeninimMT.ttf
                                            NewPeninimMTBold.ttf
                                            NewPeninimMTBoldInclined.ttf
                                            NewPeninimMTInclined.ttf
                                            NISC18030.ttf
                                            NuevaStd-BoldCond.otf
                                            NuevaStd-BoldCondItalic.otf
                                            NuevaStd-Cond.otf
                                            NuevaStd-CondItalic.otf
                                            OCRAStd.otf
                                            Optima.ttc
                                            OratorStd-Slanted.otf
                                            OratorStd.otf
                                            Osaka.ttf
                                            OsakaMono.ttf
                                            Palatino
                                            Papyrus.ttc
                                            Party LET Fonts
                                            PCmyoungjo.ttf
                                            Pilgiche.ttf
                                            PlantagenetCherokee.ttf
                                            PoplarStd.otf
                                            PortagoITC TT
                                            PrestigeEliteStd-Bd.otf
                                            Princetown LET Fonts
                                            Raanana.ttf
                                            RaananaBold.ttf
                                            RosewoodStd-Regular.otf
                                            Santa Fe LET Fonts
                                            Sathu.ttf
                                            Savoye LET Fonts
                                            SchoolHouse Cursive B.suit
                                            SchoolHouse Printed A
                                            Silom.ttf
                                            Skia.ttf
                                            Snell Roundhand
                                            StencilStd.otf
                                            STHeiti Medium.ttc
                                            Stone Sans ITC TT
                                            Synchro LET Fonts
                                            Tahoma Bold.ttf
                                            Tahoma.ttf
                                            TektonPro-Bold.otf
                                            TektonPro-BoldCond.otf
                                            TektonPro-BoldExt.otf
                                            TektonPro-BoldObl.otf
                                            Times New Roman Bold Italic.ttf
                                            Times New Roman Bold.ttf
                                            Times New Roman Italic.ttf
                                            Times New Roman.ttf
                                            TrajanPro-Bold.otf
                                            TrajanPro-Regular.otf
                                            Trebuchet MS Bold Italic.ttf
                                            Trebuchet MS Bold.ttf
                                            Trebuchet MS Italic.ttf
                                            Trebuchet MS.ttf
                                            Type Embellishmnt One LET
                                            Verdana Bold Italic.ttf
                                            Verdana Bold.ttf
                                            Verdana Italic.ttf
                                            Verdana.ttf
                                            Webdings.ttf
                                            Wingdings 2.ttf
                                            Wingdings 3.ttf
                                            Wingdings.ttf
                                            Zapfino.ttf
                                            ?????? Pro W4.otf
                                            ?????? ProN W4.otf
                                            ?????? Pro W3.otf
                                            ?????? Pro W6.otf
                                            ?????? Pro W3.otf
                                            ?????? Pro W6.otf
                                            ?????? Std W8.otf
                                            ?????? StdN W8.otf
                                            ?? Pro.ttf
                                            ????.ttf
                                            ????.ttf
                                            ????.ttf
                                            and this is the content of my users font folder:
                                            CORBEL.TTF
                                            DroidSansMono.ttf
                                            FF Meta Neu Screen
                                            GothamNarrow-Black.otf
                                            GothamNarrow-BlackItalic.otf
                                            GothamNarrow-Bold.otf
                                            GothamNarrow-BoldItalic.otf
                                            GothamNarrow-Book.otf
                                            GothamNarrow-BookItalic.otf
                                            GothamNarrow-Light.otf
                                            GothamNarrow-LightItalic.otf
                                            GothamNarrow-Medium.otf
                                            GothamNarrow-MediumItalic.otf
                                            GothamNarrow-Thin.otf
                                            GothamNarrow-ThinItalic.otf
                                            GothamNarrow-Ultra.otf
                                            GothamNarrow-UltraItalic.otf
                                            GothamNarrow-XLight.otf
                                            GothamNarrow-XLightItalic.otf
                                            IstokWeb-Bold.ttf
                                            IstokWeb-BoldItalic.ttf
                                            IstokWeb-Italic.ttf
                                            IstokWeb-Regular.ttf
                                            KozGoPr6N-Bold-AlphaNum.ttf
                                            KozGoPr6N-ExtraLight-AlphaNum.ttf
                                            KozGoPr6N-Heavy-AlphaNum.ttf
                                            KozGoPr6N-Light-AlphaNum.ttf
                                            KozGoPr6N-Medium-AlphaNum.ttf
                                            KozGoPr6N-Regular-AlphaNum.ttf
                                            KozGoPro-Bold-AlphaNum.ttf
                                            KozGoPro-Bold.otf
                                            KozGoPro-ExtraLight-AlphaNum.ttf
                                            KozGoPro-Heavy-AlphaNum.ttf
                                            KozGoPro-Light-AlphaNum.ttf
                                            KozGoPro-Medium-AlphaNum.ttf
                                            KozGoPro-Medium.otf
                                            KozGoPro-Regular-AlphaNum.ttf
                                            MetaPluBlaRom
                                            MetaPluBolCap
                                            MetaPluBolCapIta
                                            MetaPluBolIta
                                            MetaPluBolRom
                                            MetaPluBooCap
                                            MetaPluBooCapIta
                                            MetaPluBooIta
                                            MetaPluBooRom
                                            MetaPluMedCap
                                            MetaPluMedCapIta
                                            MetaPluMedIta
                                            MetaPluMedRom
                                            MetaPluNorCap
                                            MetaPluNorCapIta
                                            MetaPluNorIta
                                            MetaPluNorRom
                                            Neuzeit S
                                            NeuzeSBoo
                                            NeuzeSBooHea
                                            PENNBD__.ttf
                                            PENNI___.ttf
                                            PENNR___.ttf
                                            Rotis Family
                                            Rotis Sans Serif
                                            Rotis Semi Serif
                                            Rotis SemiS
                                            Rotis SemSans
                                            Rotis Serif
                                            RotisSanSer
                                            RotisSanSerBol
                                            RotisSanSerExtBol
                                            RotisSanSerIta
                                            RotisSanSerLig
                                            RotisSanSerLigIta
                                            RotisSemSan
                                            RotisSemSanBol
                                            RotisSemSanExtBol
                                            RotisSemSanIta
                                            RotisSemSanLig
                                            RotisSemSanLigIta
                                            RotisSemSer
                                            RotisSemSerBol
                                            RotisSer
                                            RotisSerBol
                                            RotisSerIta
                                            standard 07_55.suit
                                            standard 07_65.suit
                                            Regards
                                            Alex
                                            • 21. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                              thanks again alex.  i'm going to ask the others for their list and see if there's anything in common.
                                              • 22. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                                is there any progress already? I got an call from a customer this morning who is experiencing the same problems. Sometimes it is only Audio not working, sometimes the Player is crashing completely. What happened during the call is that he he is overthinking his decission to use flash. I mean, that decission might cost me several thousands of € the next year and I can only say to him: "Well, i am sorry but it is not my fault!".
                                                And I think it will get worse. People are just starting to update their Flash Players. Maybe Adobe should think about removing Player 11 from the download page until the problems are solved.
                                                I also have several friends, mainly Chrome Users, wanting to use the Web Audio API of the latest Chrome Release, also experiencing the same probelms, who deactivated the Flash Plugin in favour of the API. Downgrading is not an option for them.
                                                Please take this very seriously as there are a lot of people experiencing this problem. People I know but who are not commiting bugreports inside their browsers and who simply don't care whether they can use flash or not. What they care about are nasty crash messages...
                                                I am now quite sure that it has nothing to do with an extraordinary hardware or software setup. It might be the font thing, but hey, Flash Player should be able to handle that.
                                                Regards
                                                Alex
                                                • 23. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                                  Ken Lunde Adobe Employee
                                                  Alex,
                                                  Are you able to tell me where the following fonts in your users fonts directory came from?
                                                  Also, I am curious as to whether other users who have experienced this issue have them in one of their fonts folders as well.
                                                  I am asking because I am the one who built the OTF (*.otf) versions of these fonts (and without the "-AlphaNum" string in the name), and this is the first time I have seen TTF versions of them. It is unclear as to whether these fonts are the cause of the problem, but I am sure that they can be safely removed. And, if you don't mind, please send them to me (at "lunde@adobe.com") so that I can inspect them. I am curious where they came from.
                                                  Thanks...
                                                  • 24. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                                    Hitomi Kudo Level 3
                                                    Alex,
                                                    Just to let you know that Adobe Flash engineering team have been trying to reproduce your crash very hard, more than five people tried for several days since you reported, but no luck to see the crash even once. It's very hard to investigate yoru issue if we can not reproduce internally. Any hints for us to reproduce your crash is highly appreicated. (we've already read all your info in this thread)
                                                    By the way all crash isn't necessary same and it need to be distinguished by data in crash log. Other people's crash can be completely different from yours and caused by different reason. We want to track your issue in this thread.
                                                    thanks,
                                                    Hitomi
                                                    • 25. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                                      Hi Ken,
                                                      well, I am everything but a typograph. I normally use Helvetica as a failsafe font.
                                                      I just had a look in my projects and these fonts were given to me by an agency I was doing a facebook game for Davidoff for. I had to cut my one assets and the art director was (maybe) too lazy to rasterize all the text. Actually I could have erased them but then the next project started and so on. I have no idea where the .ttf versions come from. When you state that this is normally an .otf font I guess someone converted them for what reason ever.
                                                      I will send them to you.
                                                      Regards
                                                      Alex
                                                      • 26. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                                        Alex,
                                                        I look forward to receiving those fonts. A couple things to try are as follows:
                                                        • Nuke the font cache files that are used by Adobe applications by executing the following command in the Terminal application: % rm ~/Library/Caches/Adobe*/*/AdobeFnt*.lst (you can use "% ls ~/Library/Caches/Adobe*/*/AdobeFnt*.lst" to see them first).
                                                        • Remove, either temporarily or permanently, those questionable TTFs.
                                                        -- Ken
                                                        • 27. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                                          Hi Hitomi,
                                                          I am absolutely sure that you do your best. And I really appreciate you people at Adobe investigating that issue.
                                                          It is just so strange that it is not reproduceable for you. Just 15 minutes before I went home from work a coworker of mine asked me, why Flash crashes in his Chrome Browser. And he did an update of Chrome just the other day. He has exactly the same MBP as I have. Just bought it something like 3 or 4 month after me. Except he has 10.7 installed.
                                                          Last week it looked like my MBP is having a strange issue with the FP11. I did an update just right after you released the player. Then others dropped in and had the same - or as you state - similar issues. And now people are updating and some of the people I work with (in totally different parts of the indusrty) are also experiencing crashes. For some it is really only Audio which is failing. Others experience these complete crashes as I do. And there are a lot of other actionscriptdevelopers who have no problem at all.
                                                          You have to understand that I am just a little pissed that I can not play around with all the cool stuff Adobe was announcing the last year as an official release. I have no problem with uninstalling and going back to 10.3 except the fact that I will gain experience with the new APIs a little later than others do.
                                                          But from the moment the iPad came out it is often hard for me to convince people that flash is not so bad after all. And these issues are somehow adding fuel to the fire. And some of them experiencing these crashes are totally lost with uninstalling the Flash Player and reinstalling the latest release. They even do not know where to download older releases. So no Youtube because Flash is installed and no fallback seems to be neccessary. And now they blame Flash as an technology. These are mainly people using their computers for buying stuff at Amazon or using Powerpoint.
                                                          When I wrote that Adobe should consider removing the FP11 from the download page I was just asking myself if all the psychological sideeffects of these crashes are worth having FP11 released right at MAX. I did not want to blame anyone for any bugs but I guess the ratio of people commiting bugreports to those not is something like 1 to VERYVERYMANY.
                                                          Thanks for taking care...
                                                          Alex
                                                          • 28. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                                            Hi Ken,
                                                            I will give the terminal magic a try in the morning.
                                                            If you have any idea what I can do to give you more informations with which you might find out what causes the crashes... I have just no idea which information might be useful. I would never have thought that something like fonts might cause such problems.
                                                            Alex
                                                            • 29. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
                                                              Many thanks, Alex, for providing the fonts to me. I am not on the Flash team, but am in Type Development, thus my interest in fonts, and my experience that "unknown" fonts may be malformed. I am using a MacBook Pro 17-inch running Mac OS X 10.6.8. I installed the fonts into my ~/Library/Fonts folder, and Flash now crashes on a regular basis. Attached is a screenshot of what I am experiencing in Chrome. So, if you simply remove the KozGo*.ttf files (use "% rm ~/Library/Fonts/KozGo*.ttf" to remove them), the problem may go away.crash.png
                                                              • 30. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
        Hitomi Kudo Level 3
        Alex,
        Thank you for sharing your thought. I appreciate your time and effort to report the crash and your help to investigate our product isuse. Honestly speaking there are many differnt type of Flash Player crash exist. We know that as fact from browser vendor's crash report. We know customers are suffering from the crash issues. However almost all crashers are not reproducible for us even we try hard. We really need customer's (like your) help to track down those issues one by one. My mission in Flash Runtime engineering team is to engage with customers (again like you) through multiple channeles inlcuding this forum.
        If you see people who encounter Flash Player crash, please ask them to report us with their crash log so we can at least tell what kind of crash it is from crash signture. Then we can try figure out how to reproduce. Unless we see crash log we can't tell one crash is same or different with another one.
        Thank you for all your help!
        Hitomi
        • 31. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
        Hi Ken, Hi Hitomi,
        thank you so much. That actually solved my problem. No crashes in any browser anymore.
        I first removed Adobes font cache file and then got rid of the font you were stating as faulty.
        I know at least one person also experiencing this crashes and also freelancing. So he might have some crippled fonts in his users font library as well. I will spread the word...
        Thank you...
        Alex
        • 32. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
        Alex,
        Thank you for confirming that removing these 12 TTFs solved the problem. If you copy only one of these 12 TTFs back into your ~/Library/Fonts/ directory, you will start to experience this issue again. In other words, this specific issue has nothing to do with the Adobe font cache files.
        I just inspected these fonts, and the problem is in their 'name' tables, specifically that they are missing crucial strings, specifically name.IDs 1 (Font Family name) and 4 (Full Family name). These fonts include only name.IDs 2 (Font Subfamily name), 3 (Unique font identifier), 5 (Version string), and 6 (Postscript name for the font). In fact, if you use the Mac OS X "Font Book" application to validate these fonts, it will state that the 'name' table is problematic, and that the fonts should not be used.
        Please keep us posted about other customers you know who are experiencing this issue. One way to identify potentially problematic fonts is to use the Mac OS X "Font Book" application.
        -- Ken
        • 33. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
        Hi Ken,
        my coworking pal definately also had font issues as he removed some very old .ttf files(the only ones he had in his users font folder) with architectural symbols inside and no further crashes at all. I am very glad that this worked out.
        I have actually no idea what you are talking about ;-) But that is ok I think. I checked my other fonts and they seem to be ok. What frightens me a bit is the fact, that there are probably a lot of broken fonts out there. People installed them years ago and just copied their system backups without cleaning unused stuff. So I am really not surprised after all.
        What do you think? Is it possible to somehow identify those broken fonts on Flash Player startup so that they do not get loaded or whatsoever flash player is doing with them?
        Regards
        Alex
        • 34. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
        Alex,
        While I certainly cannot speak for the Flash Runtime team, because I am on the Type Development team, it seems that a prudent measure would be to check for, and guard against, malformed fonts.
        On the customer side, there is some measure of responsibility to not use such fonts, and leveraging proven tools, such as the Mac OS X "Font Book" application, specifically its function for checking the integrity of installed fonts, would be something I would strongly suggest.
        -- Ken
        • 35. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
        blackmarketbear Level 1
        I removed 123B9A_0.ttf from my /library/font/ folder and flash works perfectly now.
        I have emailed the font to adobe to look at, hope this helps.
        • 36. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
        newpappa Level 1
        Removing bad fonts resolved the problem!! So happy!
        Using Mac OS X "Font Book" application, selected File / Validate Fonts
        Removed any fonts that did not pass as safe to use
        Yes!!
        • 37. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
        I have noticed that the fonts issue has found an entirely new bug - this is insane - the fonts are no longer being recognizd when published from flash. so if i export a font from flash with actionscript, it shows up until I restart flash, I then have to go in and remove those fonts, re-insert those fonts and republish for them to be seen.
        There appears to be a serious issue with fonts.
        I do not understand why Adobe and Flash have never been able to sort out their fonts - having used flash from the start it blows my mind the fact that every edition you promise to sort out fonts, create something entirely new every edition and fail every edition.
        TLF is from hell.
        Guys - take the time, put in the effort, and make one final, concerted effort to fix fonts.
        The reality is that to get fonts working you need a degree in philosophy, masters in physics, Doctoroate in Linguistics - its ridiculous.
        • 38. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
        It would be useful to know which specific fonts are being affected by the issue that you described. Keep in mind that fonts are developed by many companies and individuals, in different formats, and using different tools. It represents a variable no doubt, but most font-related issues can be traced to a genuine issue in the affected fonts. The more useful details you provide to us, the greater the chances that we can figure out what is going on.
        • 39. Re: Flash Player 11 constantly crashing on every Website with Flashcontent...
        Any font. Arial in this instance.
        I simply have to unclick and then re-click the export font dialogue in the actionscript tab in the font properties from the library.
        I will be taking the fonts out and creating a dynamic loading library - so dont worry about me - but for others WOW.
        1 2 Previous Next
