1. Re: Will not import AC3
Bill Hunt Oct 9, 2011 5:21 PM (in response to schlossd)There are several "flavors" of AC3. Encore should Import all AC3's, that are 100% DVD-compliant, with the Dolby Digital settings.
Unless something has smurfed your DD AC3 CODEC, it is most likely that Sorenson Squeeze, with the settings used, is not creating DD AC3 files. I would Export a DD AC3 from PrPro, and then Import that into Encore as a test. If that Imports fine, then you know the CODEC is intact, and would then explore Sorenson, to see exactly what its settings are. I do not use Sorenson, so cannot tell you anything about that program's settings, but know that Jeff Bellune, our tireless MOD here, does use it, so should be able to discuss the exact settings there.
Let us know how the test goes, and by then, Jeff will likely drop by with some tips.
Good luck,
Hunt
