Hi Everyone -
Can anyone please help with this? Last week I attempted to install Flash Player 10.3.181 (I think that is the tree). All went well until a message came up stating that Settings Manager was still open and that I should close it and try again. At this point a partially installed file was left on my PC. The partial install won't run, and it has overwritten the earlier version. It's a secure file, and it won't allow me to delete it. I've tried using Unlocker, and that won't work either. I can't get to Settings Manager because that needs Flash Player. Further attempts to download result in the same loop taking place - frustrating is a polite way of putting it! I'm running Windows 7 64-bit and Internet Explorer 8. I've just tried downloading version 11, and that gives exactly the same error. Has anyone else come across this problem?
Go to http://forums.adobe.com/thread/909550 and download
then close all browser windows and run the downloaded uninstaller, followed by the installer(s).
Hi -
Thanks for that! It works in that the 64-bit uninstaller gets rid of the partial download. I can then re-install Flash Player, but only if I select an older version. Version 11 and the one before it both install partially, then give the Settings Manager message. Could this be something to do with IE?
What is the exact message you are getting? Is it about FlashPlayerCPLApp.cpl ?
If so, try to delete it from C:\Windows\syswow64 - if necessary, use Unlocker.
