So I'm rather new to preloaders in Flash. However, I found a decent tutorial online, and after completing it, began to create a preloader for my movie project. Everything was going just dandy until I viewed the movie. Because I wanted to see the preloader, I tested the movie and simulated a download... and was greeted with a white screen. I waited for some time, and suddenly the preloader appeared, loading from 80% onward. Basically, the first 79% of the preloader was represented by a blank screen. Does anybody know why I'm having this problem? If it would help, I've provided a link to the .fla file. The button isn't actionscripted yet, and the motion tween was just filler content so the preloader could be viewed. Thank you guys in advance! http://www.mediafire.com/file/7dq29r9n3e7oscj/The_Remembering.zip |
that is usually caused by having 80% of your swf's assets load before anything is visible on-stage. typically those assets consist of items exported for use by actionscript and embedded fonts.
the easiest, but not the only, remedy is to create a stand-alone preloader that contains only your preloader assets and that loads and displays the load-progress of your current swf (less the preloader assets).
So if I'm getting this right, 80% of the file is IN the preloader, thus causing this problem? When the movie gets longer (it's going to be 3-4 minutes total, currently I only have about 5 seconds motion tween), will this get somewhat remedied?
I guess I'm not completely clear on what you mean by "stand-alone preloader." Could you, by chance, point me in the direction of a webpage of video tutorial that explains this?
not usually. usually it's items exported for use by actionscript and embedded fonts.
no.
a stand-alone preloader is a swf that contains only your preloader assets and that loads and displays the load-progress of your current swf (less the preloader assets).
Here is an example to hopefully help. So this code is from the timeline of a separate swf file I created to load my main swf. My main SWF is called "ConcentricCS4.swf".
This code from frame 1 of the main timeline of my "Preloader.fla" file. I put a trace statement in there that rounds to the nearest whole number. Displaying the percentage to test. This make sense?
stop();
var myrequest:URLRequest = new URLRequest("ConcentricCS4.swf");
var myloader:Loader = new Loader();
myloader.load(myrequest);
myloader.contentLoaderInfo.addEventListener(ProgressEvent.PROGRESS, progressHandler);
myloader.contentLoaderInfo.addEventListener(Event.COMPLETE, loadFinished);
function progressHandler(event:ProgressEvent):void {
var loadprogress:Number = Math.round(event.target.bytesLoaded/event.target.bytesTotal*100);
trace(loadprogress);
Preloader.gotoAndStop(loadprogress);
function loadFinished (e:Event) {
addChild(myloader);
trace("finished");
removeChild(Preloader);
