when surfing on the internet in most of the websites i am getting this msg in internet explorer information bar up there saying " one add-on for this website did not work, check your security setting under internet settings for possible conflicts " ( i translated the msg from my language to english so it doesnt saying this exactly ). I am using windows xp home edition and internet explorer 8..i dont get this msg when i open the ssame website using firefox..and i dont get this msg when i uninstall flash player completely so it must be a conflict flashplayer working on internet explorer... my security setting under internet setting are all set to default....any ideas to fix this problem ? i can watch videos on youtube and elsewehere but this warning beep voice and msg really makes me sick..btw there is no way to download and use older flashplayer versions ? i did not have this problem with previous versions..
ok this is the msg i see on my ie information bar:
"An add-on for this website failed to run. Check the security settings in Internet options for potential conflicts"
i found the add-on causing this problem it is shockwave flash object when i disable it i dont get that irritating msg and beep anymore..but i cant watch any video on youtube without it...i tried clean uninstall using flashplayer uninstaller and install the latest flashplayer again..but still same....i guess it is not very uncommon problem i see on other forums but there is not solution..can someone help me if i can roll back my flashplayer to previous version pls ?
thank you very much
that was the page i was looking for. now i am trying to uninstall recent version and install 1 previous flash player. i hope this fix my problem otherwise i dont know what else to do beside giving up using internet explorer
nope..nothing changed it is still same...i download older version and unrar and install these:
flashplayer10_3r183_10_win - flash player installer
flashplayer10_3r183_10_win - windows installer
flashplayer10_3r183_10_win_sa
flashplayer10_3r183_10_winax - flash player installer
flashplayer10_3r183_10_winax - windows installer
i guess it is not problem if i install flash player installer files or windows installer files but i am not sure if i should install win_sa and winax named setups ...anyway i installed all of them but i still get the same warning.....anyother way to fix it?
sa is the standalone player; you probably won't need it.
ax is the ActiveX installer for Internet Explorer.
Did you uninstall the previously installed version before installing the older one?
yes i uninstall previously installed version first with flash player uninstaller
and install this one..
my mum has windows xp home edition as well and i notice the same problem in her pc too..
and xp home edition i just installed on my pc ..maybe flash and home edition doesnt match good...
anyother advice?
Can you start Internet Explorer in Safe Mode, and see if the same problem happens? If not, that would show that there is a conflict with another add-on.
If yes, what is the security setting on your IE?
