I have a problem with the some of the hyperlinks in my
WebHelp Pro project not functioning correctly once the project is
compiled. What happens is that when I click on a hyperlink the text
doesn't change from blue to purple. Not all the hyperlinks on a
page are affected; some may work while others do not.
When I look at the HTML code, I see two different things
happening, and both things may not occur in the same code:
1) In some documents the code reads "a visited=0000ff." The
value should be 800080.
2) In other documents "font color=blue" is being added to the
HTML code for a particular hyperlink. Other hyperlink code in the
same document may be unaffected.
I have checked the font color in the editor to make sure it
was set to "automatic" before I created the hyperlink. I removed
the hyperlinks altogether, recompiled, then opened the document
back up and recreated the hyperlinks. The problem still exists.
Every document in my project is using the default.css style sheet.
I use the same paragraph style throughout the project, both on the
links that work correctly and those that do not.
Has anyone ever experienced this problem? And if so, do you
know the fix? I could manually edit the HTML code before publishing
my project, but that is just a bandaid fix.
