Coldfusion Wizard and MySQL
Avatar
Level 1
Hi all,
I am new to Flex and trying to connect to a MySQl database
via the ColdFusion wizard. The wizard works fine except it never
creates the “bin/main.html” file. It creates the
“index.cfm” file that points to the
“main.html” file. The kicker is that it works fine when
you use Access as the database, and the wizard even sees the MySQL
database, allowing you to create the needed queries etc. The MySQl
database works fine in ColdFusion and I have tried multiple Access
databases and MySQL databases. All the Access databases work fine
but the MySQL ones won’t.
Has anyone else had a problem with MySQL and the wizard?
Mike
Avatar
Level 1
OK, since I first posted this problem I have had a chance to
go back and play around with flex and the wizard some more. At
first I thought it might be me, not unheard of, but I have been
able to connect the wizard successfully to some tables in some
MySQL databases. The weird thing is that there is no rhyme or
reason to why it connects. For instance I may be able to connect to
a table fine, but if I try to recreate the exact connection in a
new project it does not work. Also if you go in and make a change
to the project, one that is working, it will break it. The only
thing I can figure is that the data types in the table can cause
problems. I have noticed that Flex does give me error messages for
some text fields. So I am off to document the tables to see if
there are any data types that may be a problem.
Avatar
Level 1
Mark,
I wasn't able to reproduce the problem using a MySQL
database. The data types that were covered and worked successfully
were decimal, bigint, varchar, datetime, float, int, double,
smallint, text, timestamp, and tinyint. If you have any columns
with a data type other than these, please let me know.
Farah
CF QA Team
Avatar
Level 1
Hi Farah,
Thanks for the response. No the data types are all either
int, varchar, or text, nothing fancy.
Another thought. I have the Access database and Flex builder
on the same server but the MySQL databases are located on a
different server. Could this be a problem?
